Hello - My MIC+ application require the smallest size possible. I plan to de-solder the green screw terminals and the 3.5mm jack. Should I expect any issues if I simply leave the related PCB holes empty/unconnected?
Also, I notice that the MIC+ board looks like it may be hand soldered. If so, is it possible to buy a board without some of the connectors and components pre-soldered?
