Moduslide dead after update
Received just today the moduslide. First of all tried with the online editor, it showed there to select and couldn’t get a connection… It just stuck trying to connect. Later tried with the offline editor but it didn’t even show. Then I attempted the firmware upgradel, following the procedure and it seemet it went ok but once I tried to reconnect I found out it doesn’t even show on the online editor and has no light at all. If I press the button to boot in programming mode, the device works so I can access it with the STMCube program, but nothing more than this.
This is a firmware version issue, Gaetan is going to write you an email about it
Thanks! Looking forward to try it!
