No audio on Muse Lux in Home Assistant
I do the same, and I have no sound coming from the Muse, and it goes to idle at the very same time as it goes to play, always the same second
Have you compared logs above, found any anomalies?
it looks like a network issue
Look at this post it looks like your issue :
Could you tell me again how do I get the same logs as you? :sweat_smile:
The first log requires that you have ESP Home Addon in Home Assistant. Then in ESP Home Addon the three dots -> Validate on your application.
The second one, select the three dots on your raspiaudio integration -> Download diagnostics.
I will check the linked thread
So, NielsNL68 is mentioning how his yaml file looks like in post Aug 25. My yaml file in ESP Home only contains this:
substitutions:
packages:
raspiaudio.muse-luxe: github://esphome/media-players/raspiaudio-muse-luxe.yaml@main
esphome:
name_add_mac_suffix: false
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
Maybe I should add something like this to mine?
esp32:
board: esp-wrover-kit
framework:
type: arduino
media_player:
  • platform: i2s_audio
    dac_type: external
    i2s_lrclk_pin: GPIO25
    i2s_dout_pin: GPIO26
    i2s_bclk_pin: GPIO5
    mode: mono
    mute_pin:
    number: GPIO21
    inverted: true
Its the first time I fiddle with ESPHome
my humble thought is that you probably have nothing to change in the config, as we both have the exact same setup, this likely to be something else.
What you can try is what Niels describes in his table to check if you are in the same case, it seems to work with DLNA. So try to install a DLNA server on an android phone or compute, then install the DLNA service, and check if you can play this media source on the Luxe.
You could also try if you still have the issue on a different LAN.
So the yaml config is as it shall be?
substitutions:
packages:
esphome:
wifi:
So here is my file :sweat_smile:
“home_assistant”: {
“installation_type”: “Home Assistant OS”,
“version”: “2022.10.3”,
“dev”: false,
“hassio”: true,
“virtualenv”: false,
“python_version”: “3.10.5”,
“docker”: true,
“arch”: “aarch64”,
“timezone”: “Europe/Paris”,
“os_name”: “Linux”,
“os_version”: “5.15.61-v8”,
“supervisor”: “2022.10.0”,
“host_os”: “Home Assistant OS 9.0”,
“docker_version”: “20.10.17”,
“chassis”: “embedded”,
“run_as_root”: true
“custom_components”: {},
“integration_manifest”: {
“domain”: “esphome”,
“name”: “ESPHome”,
“config_flow”: true,
“documentation”: “https://www.home-assistant.io/integrations/esphome”,
“requirements”: [
“aioesphomeapi==11.1.0”
“zeroconf”: [
“_esphomelib._tcp.local.”
“dhcp”: [
“registered_devices”: true
“codeowners”: [
@OttoWinter”,
@jesserockz
“after_dependencies”: [
“bluetooth”,
“zeroconf”,
“tag”
“iot_class”: “local_push”,
“loggers”: [
“aioesphomeapi”,
“noiseprotocol”
“is_built_in”: true
“data”: {
“config”: {
“entry_id”: “391a8c0a6595f4e4bfd970ddbf78dd40”,
“version”: 1,
“title”: “raspiaudio-muse-luxe-f2c2c8”,
“data”: {
“host”: “192.168.112.235”,
“port”: 6053,
“password”: “”,
“noise_psk”: “”
“options”: {},
“pref_disable_new_entities”: false,
“pref_disable_polling”: false,
“source”: “zeroconf”,
“unique_id”: “raspiaudio-muse-luxe-f2c2c8”,
“disabled_by”: null
“storage_data”: {
“device_info”: {
“uses_password”: false,
“name”: “raspiaudio-muse-luxe-f2c2c8”,
“mac_address”: “REDACTED”,
“compilation_time”: “Sep 7 2022, 01:29:31”,
“model”: “esp-wrover-kit”,
“has_deep_sleep”: false,
“esphome_version”: “2022.8.3”,
“project_name”: “raspiaudio.muse-luxe”,
“project_version”: “1.0”,
“webserver_port”: 0,
“bluetooth_proxy_version”: 0
“services”: [],
“api_version”: {
“major”: 1,
“minor”: 6
“binary_sensor”: [
“object_id”: “raspiaudio_muse_luxe_volume_up”,
“key”: 3165250273,
“name”: “RaspiAudio Muse Luxe Volume Up”,
“unique_id”: “raspiaudio-muse-luxe-f2c2c8binary_sensorraspiaudio_muse_luxe_volume_up”,
“disabled_by_default”: false,
“icon”: “”,
“entity_category”: 0,
“device_class”: “”,
“is_status_binary_sensor”: false
“object_id”: “raspiaudio_muse_luxe_volume_down”,
“key”: 4118566082,
“name”: “RaspiAudio Muse Luxe Volume Down”,
“unique_id”: “raspiaudio-muse-luxe-f2c2c8binary_sensorraspiaudio_muse_luxe_volume_down”,
“icon”: “”,
“device_class”: “”,
“object_id”: “raspiaudio_muse_luxe_play_button”,
“key”: 1343665654,
“name”: “RaspiAudio Muse Luxe Play Button”,
“unique_id”: “raspiaudio-muse-luxe-f2c2c8binary_sensorraspiaudio_muse_luxe_play_button”,
“icon”: “”,
“device_class”: “”,
“media_player”: [
“object_id”: “raspiaudio_muse_luxe”,
“key”: 1434200530,
“name”: “RaspiAudio Muse Luxe”,
“unique_id”: “raspiaudio-muse-luxe-f2c2c8media_playerraspiaudio_muse_luxe”,
“icon”: “”,
“supports_pause”: true
“light”: [
“key”: 1434200530,
“unique_id”: “raspiaudio-muse-luxe-f2c2c8lightraspiaudio_muse_luxe”,
“icon”: “”,
“supported_color_modes”: [
35
“min_mireds”: 0.0,
“max_mireds”: 0.0,
“effects”: [],
“legacy_supports_brightness”: true,
“legacy_supports_rgb”: true,
“legacy_supports_white_value”: false,
“legacy_supports_color_temperature”: false
That is hardly the yaml config
This is the link to the supposed yaml code on github media-players/raspiaudio-muse-luxe.yaml at main · esphome/media-players (github.com)
Should I try that?
This is what I recommend you to try :
Thanks. I did read that thread and they came to no conclusion at all. My conclusion is that the ESPHome Media Player is pretty crappy, and looks like its not maintained.
I trided to install the Squeezelite-ESP32 firmware on the Muse yesterday but it refused and said I should hold the boot-button while trying to flash.
Any idea how I do that?
try this one
https://sle118.github.io/squeezelite-esp32-installer
Thanks. I installed and configured. I still cant play local media or TTS from Home Assistant but now I’m listening to Spotify on the Muse, controlled from my phone.
I have installed the SlimProto Player and Home Assistant recognizes the Muse as a Media Player. If I shut it off and on from Home Assistant it starts sounding a very quiet white noice when on.
If i play a song from Spotify on my Muse from my phone the Home Assistant Media Player says Nothing Playing. But I can pause it. If I then push play again the Spotify song starts a few seconds and then gets replaced by a loud white noice. I think I have read about the same behavior elsewhere.
How do you play from your phone on the muse?
I can’t seem to get bluetooth working with squeezelite, as a matter of fact, I only get audio with the following option:
All other options give no audio, and none of the three show any bluetooth devices.
I could when using this Squeezelite-ESP32 Installer (sle118.github.io) version. Now I cant anymore using this version ESPHome Media Players.
I bet the first had Airplay support or something. Everything is very erratic.
@stajo Yes, but how did you manage to play spotify using Squeezelite?
It showed up in the list of devices to play from, in my Spotify app on my iPhone
whaaat?? I’m guessing that’s what the cSpot integration is for, but it doesn’t work for me unfortunately…
Which version of Squeezelite are you on?
