hi - thanks for responding - it actually turned out to be another issue - I am trying to get Rhasspy to work with Raspiaudio - any guidance for it?
I am seeing errors like these in Rhasspy (I know this is not the Rhasspy forum, but was hoping you might be able to help:
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
[DEBUG:2021-05-18 17:00:31,443] rhasspymicrophone_pyaudio_hermes: Connected to MQTT broker
[DEBUG:2021-05-18 17:00:31,462] asyncio: Using selector: EpollSelector
[DEBUG:2021-05-18 17:00:31,482] rhasspymicrophone_pyaudio_hermes: Subscribed to hermes/audioServer/toggleSummaryOn
[DEBUG:2021-05-18 17:00:31,496] rhasspymicrophone_pyaudio_hermes: Subscribed to rhasspy/audioServer/getDevices
[DEBUG:2021-05-18 17:00:31,499] rhasspymicrophone_pyaudio_hermes: Subscribed to hermes/audioServer/toggleSummaryOff
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib conf.c:5014:(snd_config_expand) Unknown parameters {AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0}
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0}
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
Expression 'paInvalidSampleRate' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2048
Expression 'PaAlsaStreamComponent_InitialConfigure( &self->capture, inParams, self->primeBuffers, hwParamsCapture, &realSr )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2719
Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2843
[ERROR:2021-05-18 17:00:38,892] rhasspymicrophone_pyaudio_hermes: record
Traceback (most recent call last):
File "/usr/lib/rhasspy/rhasspy-microphone-pyaudio-hermes/rhasspymicrophone_pyaudio_hermes/__init__.py", line 119, in record
stream_callback=callback,
File "/usr/lib/rhasspy/.venv/lib/python3.7/site-packages/pyaudio.py", line 750, in open
stream = Stream(self, *args, **kwargs)
File "/usr/lib/rhasspy/.venv/lib/python3.7/site-packages/pyaudio.py", line 441, in __init__
self._stream = pa.open(**arguments)
OSError: [Errno -9997] Invalid sample rate
[DEBUG:2021-05-18 17:00:39,028] rhasspymicrophone_pyaudio_hermes: -> AudioRecordError(error='[Errno -9997] Invalid sample rate', site_id='default', context='Device index: 0', session_id=None)
