Hi there
I’ve been trying tot get audio playing via de ESP Muse Proto, but do not succeed.
1st started with ESP Squeezelite. Bluetooth played audio, but AirPlay showed a device, but could not connect. Integration with Home Assistant ok, but no audio will play if selected from local media.
Then found your easy installation guide and installed successfully. No bluetooth available, but now in Home Assistant I can see 3 entity’s and control the onboard LED when connected via WiFi. So it seems that Home Assistant is able to communicate with the proto board. But playing mp3/wav from Home Assistant is not working; no sound from builtin speaker or external speaker connected to the green terminals.
So I’m stuck now on resolving the audio problem. Any suggestions for me to troubleshoot this issue?
BTW: in both scenarios (easy installation and Squeezelite) the blue on board LED is flashing. Did not find and documentation on what that means. So, any clues on the status description of the blue LED?
Regards
OWK
