This is repeating over and over. I’m on ESPHome 2025.6.1 with the latest code. I’ve never seen this before. I investigated because Home Assistant speech-to-text failed which has been working for over a year. In the past when I viewed the log, all I saw was the battery voltage being reported periodically
[10:28:11][D][sensor:099]: 'Battery': Sending state 4.75450 V with 3 decimals of accuracy
[10:28:41][D][sensor:099]: 'Battery': Sending state 4.75655 V with 3 decimals of accuracy
WARNING raspiaudio-muse-luxe-bbc618 @ 192.168.1.235: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for raspiaudio-muse-luxe-bbc618 @ 192.168.1.235
WARNING Disconnected from API
INFO Successfully resolved raspiaudio-muse-luxe-bbc618 @ 192.168.1.235 in 0.000s
INFO Successfully connected to raspiaudio-muse-luxe-bbc618 @ 192.168.1.235 in 0.014s
INFO Successful handshake with raspiaudio-muse-luxe-bbc618 @ 192.168.1.235 in 0.082s
[10:29:12][D][api:133]: Accepted 192.168.1.244
[10:29:13][D][api.connection:1570]: Home Assistant 2025.6.3 (192.168.1.244) connected
[10:30:11][D][sensor:099]: 'Battery': Sending state 4.76069 V with 3 decimals of accuracy
INFO Successfully connected to raspiaudio-muse-luxe-bbc618 @ 192.168.1.235 in 0.022s
INFO Successful handshake with raspiaudio-muse-luxe-bbc618 @ 192.168.1.235 in 0.089s
[10:31:13][D][api:133]: Accepted 192.168.1.244
[10:31:13][D][api.connection:1570]: Home Assistant 2025.6.3 (192.168.1.244) connected
[10:31:41][D][sensor:099]: 'Battery': Sending state 4.75813 V with 3 decimals of accuracy
[10:32:41][D][sensor:099]: 'Battery': Sending state 4.75113 V with 3 decimals of accuracy
INFO Successfully connected to raspiaudio-muse-luxe-bbc618 @ 192.168.1.235 in 0.008s
INFO Successful handshake with raspiaudio-muse-luxe-bbc618 @ 192.168.1.235 in 0.150s
[10:33:13][D][api.connection:1570]: Home Assistant 2025.6.3 (192.168.1.244) connected
