Hi Bomberman!
Yes the proto can read the battery voltage using analog Output 33
Integration with the LED and battery voltage in Squeezelite was only done for the Luxe Speaker and could be used as an example to adapt it for the Proto, but I don’t remember if it requires a recompile or could be only done using the parameters.
Hope it helps, share the NVS file result if you make it work!
thanks
