What is the jumper wire/cable size for your male gpio pins? Is it not the same size with raspberry correct?
Here is my inventory and none of them fit firmly:
Amazon.com: Multicolored Breadboard Dupont Jumper Wires – ALLUS J7011 120Pcs 3in1 Ribbon Cables Kit, Male to Male (M/M), Female to Female (F/F), Male to Female (M/F) for Arduino and Raspberry Pi: Computers & Accessories
Amazon.com: Haitronic 120pcs 20cm length Jumper Wire/dupont cable Multicolored(10 color) 40pin M to F, 40pin M to M, 40pin F to F for prototype Breadboard/DIY/Raspberry Pi 3, 4/Orange pi/ BBC micro: bit/Makey makey: Computers & Accessories
Respond with a link on amazon that fits your pins please, or give the pin size or your male-pins-part-number. Thank you.
You can keep the dupont cables you already have, if this does not fit tight you can press a bit the end of the cable twith a pair of flat pliers.
If you want to buy something that will work out of the box here are the one I am using for prototyping:
Expansion cable works for me. Thank you!
