Home Assistant Wakeword with Muse Proto HELP
I’ve been trying to get Home Assistant Voice Assistant wakeword to function for a week now. After fumbling around with ESP8266 and ESP32 trying to get an external mic/speaker to work I stumbled on this product with both onboard and thought my prayers were answered. I’m an experienced home networker/tech nerd, but relative novice with YAML/GPIO/etc. I have seen a lot of code on getting the MUSE LUXE to work, but nothing for the Muse Proto. I assumed the Luxe was just a Proto with some additional supporting peripherals, and thought the code should translate easily, but I cannot for the life of me get it to work. I have borrowed a few people’s Luxe code and tried to adapt it, but have so far failed. I’m hoping the kind strangers on the Internet can help a guy out.
Background:
  1. Muse Proto v1.7 successfully connects to network with static IP from DHCP mapping
  2. Home Assistant OS 11.1 running in VM
  3. ESPHome Add-On 2023.11.6
  4. I have verified the TTS and STT pipelines are set up correctly as they work in the mobile app and webpage with a mic connected to the computer
  5. I assume the correct board is the esp-wrover-kit, correct?
I successfully install the code onto the Proto, but which I click the mic button on the Home Assistant…uh…Assistant it immediately shows the … bubble as if the listening session never starts. One question I have is that the code I’ve tried to copy shows the arduino framework though one of the YT video tutorials says the esp-idf framework is required to use the wakeword features…is that not accurate?
Am I correct to assume that simply referencing GPIO35 invokes the on-board microphone?
I also don’t understand the difference between using speaker and media_player.
Below is the adopted code I’ve tried to use, mostly adapted from @tetele :
On boot I get the following LED feedback: a fading yellow light (boot), then a pulsing green (wifi connected), then it sits forever on a solid bright purple, which I think is the reset_led script? Then it sometimes randomly reboots and comes back with a flashing purple/red on the status LED. If I power cycle it goes back to the solid purple (at least for a while).
So my big question is: How can I modify this to work with JUST the Muse Proto onboard mic and speaker? Thanks in advance for the help!
# Board model ESP-WROVER-kit - raspiaudio - raspiaudio.com
# Board pinout diagram - https://forum.raspiaudio.com/t/muse-proto-board/231
# Code excerpted from https://gist.github.com/tetele/5cac735174527c3b373b10db8d9c8d77
# Pinout map (from backside)
# PIN   LABEL     FCN              | LABEL       FCN
# 1     GND       Ground           | GND         Ground
# 2     23        GAIN_AMPLI       | +3v3        VDD3V3
# 3     22        NEOPIXEL         | +3v3        VDD3V3
# 4     TXD       U0TXD            | RST         RST/EN
# 5     RXD       U0RXD            | VP          SENSOR VP
# 6     21        ENABLE_AMPLI     | VN          SENSOR VN
# 7     19        GPIO19           | 34          SD_DETECT
# 8     18        GPIO18           | 35          I2S_CODEC_ASDOUT
# 9     5         I2S_CODEC_SCLK   | 32          GPIO32
# 10    4         GPIO4            | 33          BAT_MONITOR
# 11    0         IO0              | 25          I2S_CODEC_LRCK
# 12    2         SD_D0            | 26          I2S_CODEC_DIN
# 13    15        SD_CMD           | 27          AUX_DETECT_IO
# 14    SD1       SDI/SD1          | 14          SD_CLK
# 15    SD0       SDO/SD0          | 12          GPIO12
# 16    CLK       SCK/CLK          | 13          SD_D3
# 17    VBAT      VBA^             | SD2         SHD/SD2
# 18    5V        +5V              | SD3         SWP/SD3
# 19    GND       Ground           | CMD         SCS/CMD
# 20    GND       Ground           | GND         Ground
esphome:
  friendly_name: Muse-lux-clone-code
  name_add_mac_suffix: false
  min_version: 2023.10.1
  on_boot:
    then:
      - output.turn_on: dac_mute
      - light.turn_on:
          effect: slow_pulse
          red: 100%
          green: 60%
          blue: 0%
esp32:
  board: esp-wrover-kit
  framework:
    type: arduino
logger:
api:
  services:
    - service: start_va
      then:
        - voice_assistant.start
    - service: stop_va
      then:
        - voice_assistant.stop
  encryption:
    key: "7LHFlAioCBO90RvMnr3lkXzKHdpwUmYhkfXqb05+hyo="
ota:
  password: "c2cc7d20564dd25d1faec06b3a51e00c"
i2c:
  sda: GPIO18
  scl: GPIO23
wifi:
  ssid: !secret not_wifi_ssid
  password: !secret not_wifi_password
captive_portal:
improv_serial:
external_components:
  - source: github://pr#3552 # DAC support https://github.com/esphome/esphome/pull/3552
    components: [es8388]
    refresh: 0s
es8388:
globals:
  - id: wifi_connected
    type: bool
    initial_value: "false"
    restore_value: false
interval:
  - interval: 1s
    then:
      - if:
          condition:
            and:
              - lambda: "return !id(wifi_connected);"
              - wifi.connected:
          then:
            - globals.set:
                value: "true"
            - light.turn_on:
                effect: pulse
                red: 0%
                green: 100%
                blue: 0%
            - delay: 1s
            - light.turn_off: top_led
output:
  - platform: gpio
    pin: GPIO21
    inverted: true
i2s_audio:
  - i2s_lrclk_pin: GPIO25
    i2s_bclk_pin: GPIO5
media_player:
  - platform: i2s_audio
    dac_type: external
    i2s_dout_pin: GPIO26
    mode: stereo
    on_state:
      if:
        condition:
          media_player.is_playing:
        then:
          output.turn_off: dac_mute
        else:
microphone:
    i2s_din_pin: GPIO35
    adc_type: external
    pdm: false
voice_assistant:
  microphone: luxe_microphone
  media_player: luxe_out
  use_wake_word: true
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: pulse
  on_tts_start:
    - light.turn_on:
        blue: 60%
        red: 20%
        green: 20%
        effect: none
  on_tts_end:
    - media_player.play_media: !lambda return x;
    - light.turn_on:
        blue: 60%
        red: 20%
        green: 20%
        effect: pulse
    # This is useful when you want to stream the response on another media_player
    # - homeassistant.service:
    #     service: media_player.play_media
    #     data:
    #       entity_id: media_player.some_speaker
    #       media_content_id: !lambda 'return x;'
    #       media_content_type: music
    #       announce: "true"
  on_client_connected:
    - if:
        condition:
          - switch.is_on: use_wake_word
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
  on_end:
    - delay: 100ms
    - wait_until:
        not:
          media_player.is_playing: luxe_out
    - script.execute: reset_led
  on_error:
    - light.turn_on:
        blue: 0%
        red: 100%
        green: 0%
        effect: none
    - delay: 1s
    - script.wait: reset_led
    - lambda: |-
        if (code == "wake-provider-missing" || code == "wake-engine-missing") {
          id(use_wake_word).turn_off();
sensor:
  - platform: adc
    pin: GPIO33
    device_class: voltage
    unit_of_measurement: "V"
    accuracy_decimals: 2
    state_class: measurement
    entity_category: diagnostic
    update_interval: 15s
    attenuation: auto
    filters:
      - multiply: 2 # https://forum.raspiaudio.com/t/esp-muse-luxe-bluetooth-speaker/294/12
      - exponential_moving_average:
          alpha: 0.2
          send_every: 2
      - delta: 0.002
    on_value:
      then:
        - sensor.template.publish:
            state: !lambda "return x;"
  - platform: template
    device_class: battery
    unit_of_measurement: "%"
    accuracy_decimals: 0
    filters:
      - calibrate_polynomial:
          degree: 3
          datapoints:
            - 4.58 -> 100.0
            - 4.5 -> 97.1
            - 4.47 -> 94.2
            - 4.44 -> 88.4
            - 4.42 -> 82.7
            - 4.41 -> 76.9
            - 4.41 -> 71.1
            - 4.37 -> 65.3
            - 4.35 -> 59.5
            - 4.31 -> 53.8
            - 4.28 -> 48.0
            - 4.26 -> 42.2
            - 4.23 -> 36.4
            - 4.21 -> 30.6
            - 4.19 -> 24.9
            - 4.16 -> 19.1
            - 4.1 -> 13.3
            - 4.07 -> 10.4
            - 4.03 -> 7.5
            - 3.97 -> 4.6
            - 3.82 -> 1.7
            - 3.27 -> 0.0
      - lambda: return clamp(x, 0.0f, 100.0f);
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO19
      inverted: true
      mode:
        input: true
        pullup: true
    on_click:
      - media_player.volume_up: luxe_out
  - platform: gpio
    pin:
      number: GPIO32
      inverted: true
      mode:
        input: true
        pullup: true
    on_click:
      - media_player.volume_down: luxe_out
  - platform: gpio
    pin:
      number: GPIO12
      inverted: true
      mode:
        input: true
        pullup: true
    on_click:
      - if:
          condition:
            switch.is_off: use_wake_word
          then:
            - if:
                condition: voice_assistant.is_running
                then:
                else:
                  - voice_assistant.start:
          else:
            - delay: 1s
light:
  - platform: esp32_rmt_led_strip
    pin: GPIO22
    chipset: SK6812
    num_leds: 1
    rgb_order: grb
    rmt_channel: 0
    default_transition_length: 0s
    gamma_correct: 2.8
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
      - pulse:
          transition_length: 1s
          update_interval: 2s
script:
  - id: reset_led
    then:
      - if:
          condition:
          then:
            - light.turn_on:
                blue: 100%
                red: 100%
                green: 0%
                brightness: 100%
                effect: none
          else:
switch:
    name: Use Wake Word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
Hi!
The Proto does not use a codec but direct I2S DAC and Microphone, so no need of the “i2c” part nor the “external_components”
have you checked this : firmware/media-player/raspiaudio-muse-proto.yaml at main · esphome/firmware · GitHub ?
especially the “channel” part :
microphone:
  • platform: i2s_audio
    channel: left
    i2s_din_pin: GPIO35
    adc_type: external
    pdm: false
as maybe by default your yaml requests the microphone right channel that does not exist
Thanks, I’m trying that code, but it’s still not functioning on the wakeword. I’ll play with it some more and let you know.
Also, that code still uses the external speaker. I don’t currently have one, so how can I route the audio to use the onboard speaker?
[SOLVED]
That link didn’t quite work, but browsing around the same github, I found one that did:
https://github.com/esphome/firmware/blob/main/voice-assistant/raspiaudio-muse-proto.yaml
It now works!
how did you install it?
It is really confusing with the different web installers and preconfigured installers available (e.g. the raspiaudio web installer, at least two esphome webinstallers…?)
I tried using ESP Webtools here ESP Web Tools and then copypasting the yaml file you linked in Home Assistant / ESP Home. But the device then never wakes up after the initial install.
And can you confirm that the Proto now still also works as a media player in HA? I think I tried a version a month or two ago where the Voice Assistant worked, but you couldn’t use it as a media player.
First the media player question: No it doesn’t work as a media player. That wasn’t a goal of mine, so I didn’t seek it out. Also, the media_player section is notably absent in this yaml. I suspect it may be possible, but I’m not smart enough yet on yaml or esphome to make it work. Maybe a future project.
As for the install, I use the ESPHome add-on in Home Assistant, but you have also to install the USB-to-serial drivers on your machine first.
Assuming your code is actually being put on your device, I suspect your problem is one of two things:
  1. Either you aren’t adding it to the ESPHome integration after install; or
  2. You’re straight copy/pasting someone’s yaml which means it doesn’t have your device-specific api and ota keys. When ESPHome creates a project, it generates two encryption keys: api and ota. My understanding is that the api key is generated to allow the device to securely communicate with Home Assistant via the ESPHome integration. The ota key is (I believe) to allow updating of some kind via wifi after the initial setup, but I don’t really understand that one.
Below are the steps I used to get the code installed and the device working:
  1. This is assuming you have HAOS or Supervisor because we’re going to be using Add-Ons
  2. Install the serial drivers found here https://www.silabs.com/developers/usb-to-uart-bridge-vcp-drivers. [If you don’t want to trust some Internet rando sending a link, you can google ESP32 serial drivers which will link you to a doc by espressif (the makers of the ESP chips) which will contain the same link, but it never hurts to be careful!]
  3. Go to Add-Ons → Add and install ESPHome Add-on. Once installed click the “Open WebUI” button.
  4. Click “New Device” and name it whatever you want (mine is ha-voice-muse-proto). Skip the “Installation” step. When asked for board, just choose the standard ESP32. The next step gives you your API key. It puts it in the config automatically, but just in case you paste over it…
  5. Click “Edit” on your new device. Copy/Paste your yaml. NOTE: This is where you need to make sure you preserve the api and ota keys. Also make sure the wifi section matches your setup. Click save.
  6. Click “Install” → Windows should prompt you with a popup for a device (COM# depending on your USB setup, but usually something other than COM1). This will take a while.
  7. After a bit it should reboot, the code does a nifty status check with the LED.
  8. On your network, find the IP of the device - I check my router to look for new DHCP leases. After first boot I found the DHCP IP, then assigned a static IP by mapping on my router, but you can do it in the yaml in the wifi section if you want like below. Or if you use secrets.yaml you can do that. NOTE: Your secrets.yaml file must be in the config/esphome/ folder on your HA server.
wifi:
  ssid: MyHomeNetwork
  password: VerySafePassword
  # Set manual IP
  manual_ip:
    static_ip: 192.168.0.123
    gateway: 192.168.0.1
    subnet: 255.255.255.0
  1. Then you have to go into Devices and Services and click Add Integration
  2. Search for ESPHome
  3. It will prompt you for the IP of the ESPhome device. Enter it and keep the port the same.
  4. The last thing you need to do is go back into Devices and Services and select the ESPHome Integration. You should see your device listed there by whatever you named it. Click “Configure” and check the box to “Allow the device to make Home Assistant service calls.”
  5. After that it should be up and running. My code has a slowly pulsing cyan led while listening, pulsing blue while detecting.
I did slightly modify the yaml, so I’ve pasted mine below (with painstaking pinout I created because the documentation all shows top of the board, but the writing is on the bottom). It adds a wifi status check, so on boot when it connects to wifi the LED will briefly turn green. I also toned down the brightness of the LEDs and changed the colors. The only things you’d have to change is the wifi info that I have in my secrets.yaml file and your device-specific keys which are created by ESPHome.
Hope this helps!
# Home Assistant Wakeword Speaker
# Everything Smart Home - https://www.youtube.com/watch?v=zhlIaBG3Ldo
# Code modified from https://github.com/esphome/firmware/blob/main/voice-assistant/raspiaudio-muse-proto.yaml
# Board model esp-wrover-kit // ESP Muse Proto - raspiaudio.com
# GPIO 0 = Button next to speaker jack
# GPIO 22 = onboard LED (NEOPIXEL)
esphome:
  friendly_name: ha-voice-muse-proto
#  name_add_mac_suffix: true
  project:
    name: raspiaudio.muse-proto-voice-assistant # Author's project
    version: "1.0"
  min_version: 2023.11.1
  on_boot:
      then:
        - light.turn_on:
            red: 100%
            green: 100%
            blue: 100%
            brightness: 20%
            effect: none
esp32:
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ######## specific to your device ############
ota:
  password: ######## specific to your device ############
#dashboard_import:
#  package_import_url: github://esphome/firmware/voice-assistant/raspiaudio-muse-proto.yaml@main
wifi:
  ssid: ######## specific to your device ############
  on_connect:
    - delay: 5s # Gives time for improv results to be transmitted
    - ble.disable:
  on_disconnect:
    - ble.enable:
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
captive_portal:
improv_serial:
esp32_improv:
  authorizer: none
globals:
    type: bool
interval:
  - interval: 2s
    then:
      - if:
          condition:
            and:
              - wifi.connected:
          then:
            - globals.set:
                value: "true"
            - light.turn_on:
                red: 0%
                green: 100%
                blue: 0%
                brightness: 20%
                effect: none
            - delay: 3s
            - light.turn_off: led
button:
  - platform: factory_reset
  - source: github://pr#5230
    components:
      - esp_adf
    refresh: 0s
i2s_audio:
    i2s_bclk_pin: GPIO5
microphone:
    channel: left
    i2s_din_pin: GPIO35
    adc_type: external
    pdm: false
speaker:
    dac_type: external
    mode: mono
output:
  - platform: gpio
    pin:
      number: GPIO21
      inverted: true
esp_adf:
voice_assistant:
  microphone: board_microphone
  speaker: board_speaker
  use_wake_word: true
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  vad_threshold: 3
  on_listening:
    - output.turn_on: mute_pin
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Slow Pulse"
  on_stt_vad_end:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Fast Pulse"
  on_tts_start:
    - output.turn_off: mute_pin
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: none
  on_end:
    - delay: 150ms
    - wait_until:
        not:
          speaker.is_playing:
  on_error:
    - light.turn_on:
        blue: 0%
        red: 100%
        green: 0%
        brightness: 100%
        effect: none
    - delay: 1s
    - if:
        condition:
        then:
    - if:
        condition:
        then:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      inverted: true
      mode:
        input: true
        pullup: true
    disabled_by_default: true
    on_multi_click:
      - timing:
          - ON for at least 250ms
          - OFF for at least 50ms
        then:
          - if:
              condition:
              then:
                - if:
                    then:
                    else:
              else:
                - delay: 1s
      - timing:
          - ON for at least 10s
        then:
          - button.press: factory_reset_btn
light:
    rmt_channel: 0
    pin: GPIO22
    chipset: WS2812
    num_leds: 1
    rgb_order: grb
    effects:
      - pulse:
          transition_length: 500ms
          update_interval: 500ms
          min_brightness: 25%
          max_brightness: 50%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 25%
          max_brightness: 50%
script:
  - id: reset_led
    then:
      - if:
          condition:
          then:
            - light.turn_on:
                red: 0%
                green: 100%
                blue: 100%
                brightness: 15%
          else:
switch:
    name: Use wake word
    optimistic: true
    entity_category: config
    on_turn_on:
      - if:
          condition:
            not:
          then:
    on_turn_off:
