Is there a way to disable the flashing blue battery charging LED? There is a topic from a year ago where @Raspiaudio says they will make this possible in the next version but I don’t see anything since. Thanks!
I think it’s tied directly to the battery charging circuit and it’s not controllable via software? I just stuck a piece electrical tape over it. You could possibly unsolder the LED if you never plan on using a battery with it, although I’m not sure if that would mess anything else up?
Yes this is correct the blue led can’t be controlled by software. And even in the next version for the LUXE we are making we had to leave on hardwired led when USB is plugged in as it is quite useful for debugging.
