LED wont change color or turn off
has anyone else noticed with recent upgrades to esphome that now the LED stops responding, tried reflashing firmware and checked yaml and still correct. Also I notice that there are a lot of errors
Compiling /data/museluxe/.pioenvs/museluxe/lib9d4/FastLED/lib8tion.cpp.o
In file included from /data/museluxe/.piolibdeps/museluxe/FastLED/platforms/esp/32/clockless_rmt_esp32.h:95,
from /data/museluxe/.piolibdeps/museluxe/FastLED/platforms/esp/32/fastled_esp32.h:8,
from /data/museluxe/.piolibdeps/museluxe/FastLED/platforms.h:36,
from /data/museluxe/.piolibdeps/museluxe/FastLED/FastLED.h:52,
from /data/museluxe/.piolibdeps/museluxe/FastLED/FastLED.cpp:2:
/data/cache/platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/esp_hw_support/include/esp_intr.h:8:2: warning: #warning esp_intr.h is deprecated, please include esp_intr_alloc.h instead [-Wcpp]
from /data/museluxe/.piolibdeps/museluxe/FastLED/bitswap.cpp:2:
from /data/museluxe/.piolibdeps/museluxe/FastLED/colorpalettes.cpp:4:
from /data/museluxe/.piolibdeps/museluxe/FastLED/colorutils.cpp:7:
from /data/museluxe/.piolibdeps/museluxe/FastLED/hsv2rgb.cpp:4:
from /data/museluxe/.piolibdeps/museluxe/FastLED/lib8tion.cpp:3:
In file included from /data/museluxe/.piolibdeps/museluxe/FastLED/platforms/esp/32/fastled_esp32.h:8,
/data/museluxe/.piolibdeps/museluxe/FastLED/platforms/esp/32/clockless_rmt_esp32.h: In member function ‘void ClocklessController<DATA_PIN, T1, T2, T3, RGB_ORDER, XTRA0, FLIP, WAIT_TIME>::startOnChannel(int)’:
/data/museluxe/.piolibdeps/museluxe/FastLED/platforms/esp/32/clockless_rmt_esp32.h:399:52: warning: ‘esp_err_t rmt_set_pin(rmt_channel_t, rmt_mode_t, gpio_num_t)’ is deprecated: use rmt_set_gpio instead [-Wdeprecated-declarations]
rmt_set_pin(mRMT_channel, RMT_MODE_TX, mPin);
In file included from /data/museluxe/.piolibdeps/museluxe/FastLED/platforms/esp/32/clockless_rmt_esp32.h:97,
/data/cache/platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/driver/include/driver/rmt.h:930:11: note: declared here
esp_err_t rmt_set_pin(rmt_channel_t channel, rmt_mode_t mode, gpio_num_t gpio_num)
Compiling /data/museluxe/.pioenvs/museluxe/lib9d4/FastLED/noise.cpp.o
Compiling /data/museluxe/.pioenvs/museluxe/lib9d4/FastLED/platforms.cpp.o
Compiling /data/museluxe/.pioenvs/museluxe/lib9d4/FastLED/power_mgt.cpp.o
Compiling /data/museluxe/.pioenvs/museluxe/lib9d4/FastLED/wiring.cpp.o
from /data/museluxe/.piolibdeps/museluxe/FastLED/noise.cpp:2:
from /data/museluxe/.piolibdeps/museluxe/FastLED/power_mgt.cpp:2:
from /data/museluxe/.piolibdeps/museluxe/FastLED/wiring.cpp:2:
Compiling /data/museluxe/.pioenvs/museluxe/src/esphome/components/adc/adc_sensor.cpp.o
Compiling /data/museluxe/.pioenvs/museluxe/src/esphome/components/api/api_connection.cpp.o
Compiling /data/museluxe/.pioenvs/museluxe/src/esphome/components/api/api_frame_helper.cpp.o
I got this error also. I am unable to control the LED as well.
