Lightweight ESPHome Sendspin firmware for the (old) Muse Luxe — native components, ESPHome 2026.10, stable multiroom in PCM
Hi all,
My first-gen Muse Luxe was headed for a drawer, so I spent a few weeks making it a reliable Sendspin player for Music Assistant. The result is a stripped-down ESPHome config, 100 %
native components (no external_components, no PRs):
:backhand_index_pointing_right: GitHub - rollyfx/muse-luxe-sendspin · GitHub
Why not just the official esphomeLuxeMusic? On the original ESP32-WROVER it runs out of memory: 2 MB Sendspin buffer, mixer, two resamplers and an announcement pipeline. Music starts and
then drops. My config keeps one media path (sendspin_source → speaker → ES8388), a 1 MiB buffer and 100 ms I²S buffers, and removes captive portal, improv, battery sensor and the startup
sound.
A few findings that may help people in the “no sound” and “stuttering” threads:
  • No sound with the native es8388 component: it never writes DACPOWER (0x04), so LOUT1/ROUT1 stay off. Fix: i2s_mclk_pin: GPIO0 + mclk_multiple: 256, and a select.set: LINE1 on
    dac_output at boot. No need for the old driver.
  • Random reboots every 2–5 min in group playback: heap corruption in the FLAC decoder on this chip. I advertise codecs: [pcm] and MA transcodes to PCM 48 kHz/16-bit mono — rock solid
    since. Opus overflows the sync task stack, so it’s PCM or nothing for now.
  • “Timeouts, is it hardware?”: at the default max output_power (20.5 dBm) with the amp enabled the CPU froze silently (no log, no network). 11.5 dB fixed it. Looks like an RF brownout,
    not a broken unit.
  • Player stays unavailable after a reboot: add the speaker’s fixed IP to “manual discovery IP addresses” in the Sendspin provider, so it doesn’t depend on mDNS.
  • ESPHome 2026.10 requires MA ≥ 2.10.7 (encrypted Sendspin). MA updates have also reset my player’s codec/delay settings twice — worth re-checking after each update.
Limitations: no voice assistant, no battery readout, PCM only. It’s a music player, nothing else. The README has the GPIO map and MA settings; JOURNAL.md has the full diagnostics if you
like backtraces.
Feedback welcome, especially from anyone willing to try FLAC on ESPHome 2026.10 (new microFLAC) and tell me whether it still crashes.
Bonjour Alex12
Have you tried the latest version of esphomeLuxeMusic? It’s version 2026.9.3, released 3 or 4 weeks ago. It works “perfectly.” For instance, I’m currently using it with an “old” Luxe, synced with a MuseRadio all day long, with no notable issues.
(A new version is coming out in a few days; it will support both Voice and Music Assistant.)
In any case, great work!
See you soon,
Sb
=> GitHub - RASPIAUDIO/esphomeLuxeMusic · GitHub
or
=> raspiaudio.github.io => Luxe => Musicassistant
Ho, cool! I started looking into this issue back in August but hadn’t checked the RASPIAUDIO/espHomeLuxeMusic repo since.
I’ll take another look and test the upcoming version to see if it’s any better than before.
Hey, fantastic news that you’re just days away from a version that will support both Voice and Music Assistant! When and where is it coming out? I’m eagerly waiting and, if you need testers, I’d be more than happy to help.
i didn’t look at the older devices for a while, but updated them now with pairing, adjustable delay, and stop word, both the player only and VA version play well on the old muse luxe :+1:
the VA version also use full duplex from the upcoming 2026.11
edit: on the VA version the startup sound is same as the timer finished sound to save flash space, it’s tight :slight_smile:
Thanks for sharing! However, I can’t see any trace of VA in muse_wrover/Muse_Luxe-VA.yaml at main · RealDeco/muse_wrover · GitHub (last commit seems to have removed all of it) - am I missing something?
fixed now, put the wrong yaml by mistake
I just got an update notice for my Muse luxe ver2026.10.0 in Home Assistant. I updated it, and now it doesn’t work at all. I have been using it for years with Chime TTS. It looks like you changed all the attributes. Thanks
Wow, it works like a charm on Muse Luxe V1!
It can’t stand more than one wakeword at a time, but overall it’s very smooth, and it’s just great that we can now have both a great synchronized Sendspin player and a voice assistant on this device.
It’s really impressive how much ESPHome has improved (and keeps improving) in the last few months. Kudos to them!
yes space is low on the v1, v2 owners could easily add more wake words, it might be possible with two on the v1 by changing the defaul partitioning but then people will have to flash with cable first time so i didn’t take that path..
It’s not a space issue for me - I removed some components to make room for a second wake word.
It’s rather a performance issue - when I activate both wake word 1 and 2, the log starts being flooded with these warnings: “Not enough free bytes in ring buffer to store incoming audio data. Resetting the ring buffer. Wake word detection accuracy will temporarily be reduced."
With a single active wake word, I see these warnings once every 10 seconds and wake word detection is not noticeably affected.
curious what you removed?, and yeah the wake word buffering issues always been there now and then and i think it’s being adressed in the next esphome release if i don’t recall wrong :eyes:
I removed mainly the timer logic and the related stop word (I don’t use timers). I can share my yaml if interested.
Really looking forward to further ESPHome optimizations that will allow to achieve even more with the same hardware!
why would you remove that, the most useful feature :eyes::man_shrugging:t3:
i think there will be less and less focus on the older esp32wrover, the S3 models been standard for a long time now and devs are working on P4 and S31
we already squeeze out the last life of these poor wrovers pushing it to it’s max, so don’t expect miracles
it’s a good transition to show our work for the future Mn Cast V2 that will run on S31 (as soon as available in volume), here an adatpation on Squeezelite ESP for S31
