I currently have the latest Squeezelite-esp32 loaded on a couple MUSE Luxe speakers. Whenever I reboot these speakers or play a track after nothing has been playing recently, I get a loud burst of static noise.
The static is so jarring the wife is refusing to use these speakers if I can’t find a solution… Anybody want to buy a couple Muse Luxe speakers?
Here is my current NVS Config:
"a2dp_ctmt": "1000",
"a2dp_ctrld": "500",
"a2dp_dev_name": "Studio Speaker",
"a2dp_sink_name": "SMSL BT4.2",
"a2dp_spin": "0000",
"actrls_config": "buttons",
"airplay_name": "Studio Speaker",
"airplay_port": "5000",
"ap_channel": "1",
"ap_ip_address": "192.168.4.1",
"ap_ip_gateway": "192.168.4.1",
"ap_ip_netmask": "255.255.255.0",
"ap_pwd": "squeezelite",
"ap_ssid": "Studio Speaker",
"autoexec": "1",
"autoexec1": "squeezelite -o I2S -b 500:2000 -d all=info -C 30 -W -n \"Studio Speaker\"",
"bat_config": "channel=5,scale=7.48,atten=3,cells=1",
"bt_name": "Studio Speaker",
"bt_sink_pin": "1234",
"bt_sink_volume": "127",
"buttons": "[{\"gpio\":32, \"pull\":true, \"debounce\":10, \"normal\":{\"pressed\":\"ACTRLS_VOLDOWN\"}}, {\"gpio\":19, \"pull\":true, \"debounce\":40, \"normal\":{\"pressed\":\"ACTRLS_VOLUP\"}}, {\"gpio\":12, \"pull\":true, \"debounce\":40, \"long_press\":1000, \"normal\":{\"pressed\":\"ACTRLS_TOGGLE\"},\"longpress\":{\"pressed\":\"ACTRLS_POWER\"}}]",
"bypass_wm": "0",
"cspot_config": "{\t\"deviceName\":\t\"Studio Speaker\",\t\"bitrate\":\t160}",
"dac_config": "model=I2S,bck=5,ws=25,do=26,di=35,i2c=16,sda=18,scl=23,mck",
"dac_controlset": "{\"init\":[ {\"reg\":0,\"val\":128}, {\"reg\":0,\"val\":0}, {\"reg\":25,\"val\":4}, {\"reg\":1,\"val\":80}, {\"reg\":2,\"val\":0},\t{\"reg\":8,\"val\":0}, {\"reg\":4,\"val\":192},\t{\"reg\":0,\"val\":18}, {\"reg\":1,\"val\":0}, {\"reg\":23,\"val\":24}, {\"reg\":24,\"val\":2}, {\"reg\":38,\"val\":9}, {\"reg\":39,\"val\":144}, {\"reg\":42,\"val\":144}, {\"reg\":43,\"val\":128}, {\"reg\":45,\"val\":128}, {\"reg\":27,\"val\":0}, {\"reg\":26,\"val\":0}, {\"reg\":2,\"val\":240}, {\"reg\":2,\"val\":0},\t{\"reg\":29,\"val\":28}, {\"reg\":4,\"val\":48}, {\"reg\":25,\"val\":0}, {\"reg\":46,\"val\":33}, {\"reg\":47,\"val\":33} ]}",
"dhcp_tmout": "8",
"display_config": "",
"enable_airplay": "N",
"enable_bt_sink": "Y",
"enable_cspot": "N",
"equalizer": "0,0,0,0,0,0,0,0,0,0",
"eth_config": "",
"ethtmout": "8",
"gpio_exp_config": "",
"host_name": "Studio Speaker",
"i2c_config": "",
"jack_mutes_amp": "n",
"led_brightness": "",
"lms_ctrls_raw": "n",
"metadata_config": "",
"ota_erase_blk": "249856",
"ota_prio": "6",
"ota_stack": "10240",
"pollmin": "15",
"pollmx": "600",
"rel_api": "https://api.github.com/repos/sle118/squeezelite-esp32/releases",
"release_url": "https://github.com/sle118/squeezelite-esp32/releases",
"rotary_config": "",
"set_GPIO": "",
"spdif_config": "",
"spi_config": "mosi=15,miso=2,clk=14",
"stats": "N",
"target": "muse",
"telnet_block": "500",
"telnet_buffer": "40000",
"telnet_enable": "Y"
