there is only a silent 5 second clip.
If I change the .asoundrc file to the one in the google guide then I can record audio by specifying the device
arecord -D mic --format=S16_LE --duration=5 --rate=16000 --file-type=raw out.raw
and play it back fine. But running without “-D mic” results in 5 seconds of silence again.
I’m confused as to why the test script works, but the arecord doesn’t. I think this is leading to the voice assistant not being able to record audio properly.
This has been driving me insane, so any help would be greatly appreciated!
in the script I am using this command to record, does this commands works for you?
arecord -d4 --rate=44000 /home/pi/test.wav&
if yes try to add your parameter one by one to check which one is causing the failure, maybe (not tested) this is the low sample rate that you have set.
Thanks for the reply.
I’ve found that the problem is related to permissions somehow. The audio only records when arecord run with sudo privilege. I noticed this when running your test script locally without using wget. Strangely, I don’t get a permission denied when I try to record, it just doesn’t work. Also pi is in the audio user group and aplay works fine without sudo.
I don’t recall this was a problem when I set-up the hat on my pi4. Do you have an idea of how to fix this? As the google-assistant still can’t access the recorder.
Thanks again
