Microphone quality
I tried record2.ino with Muse Luxe. I recorded 2 wavs, one with USB cable plugged in, the other without the USB cable.
There is a background noise on both wavs and the one without the USB cable is more accentuated.
Is there a solution to increase the recording quality?
Can you share the wiring diagram of the microphone with the codec ?
please share your recording
Recording without USB cable:
Pretty bad indeed! let me check the code :sweat_smile:
The code come from “record2.ino”, I added wifi connection and I switch frequency to 22Khz
// ***** Muse LUXE as a simple recorder*****
// -- records sound on a SD .wav file (BUTTON_PAUSE to start/stop recording)
// -- plays it
#include "museWrover.h"
#include "ESP_I2S.h"
#include "wav_header.h"
#include "driver/gpio.h"
#include "SPI.h"
#include "SD.h"
#include "FS.h"
#include <WiFi.h>
#include "esp_wifi.h" // Include ESP-IDF WiFi control functions
const char *ssid = "mySSID";          // Change this to your WiFi SSID
const char *password = "myPassword";  // Change this to your WiFi password
// Serveur TCP
const char* serverIP = "myServerIP";   // IP du serveur
const uint16_t serverPort = 8765;         // Port du serveur
WiFiClient client;
uint32_t timestamp = 0;
int volume = 100;                            // 0...100
int microVol = 96;                           // 0...96
File f;
// Initialize your objects and variables
I2SClass i2s;
ES8388 es;
pcm_wav_header_t H = PCM_WAV_HEADER_DEFAULT(0, 16, 22000, 2);
void setup() {
  Serial.begin(115200);
  // Connexion au WiFi
    Serial.print("Connexion à ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    while (WiFi.status() != WL_CONNECTED) {
        delay(500);
        Serial.print(".");
    esp_wifi_set_max_tx_power(15);
    Serial.println("\nWiFi connecté !");
    Serial.print("Adresse IP : ");
    Serial.println(WiFi.localIP());
    // Connexion au serveur TCP
    Serial.print(serverIP);
    Serial.print(":");
    Serial.println(serverPort);
    if (client.connect(serverIP, serverPort)) {
        Serial.println("Connexion réussie !");
        // Envoyer un message au serveur
        client.println("Hello, serveur !");
    } else {
        Serial.println("Échec de connexion !");
    timestamp = millis();
////// GPIOs init
  // power enable
  gpio_reset_pin(GPIO_PA_EN);
  gpio_set_direction(GPIO_PA_EN, GPIO_MODE_OUTPUT);
  gpio_set_level(GPIO_PA_EN, HIGH);
  // PAUSE
  gpio_reset_pin(BUTTON_PAUSE);
  gpio_set_direction(BUTTON_PAUSE, GPIO_MODE_INPUT);
  gpio_set_pull_mode(BUTTON_PAUSE, GPIO_PULLUP_ONLY);
  // SD init
  SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI);
  SPI.setFrequency(1000000);
  if( !SD.begin(SD_CS))
    printf( "SD init failed\n");
    while(1);
  printf("SD init OK\n");
//////I2S init
  i2s.setPins(I2S_BCLK, I2S_LRCK, I2S_SDOUT, I2S_SDIN, I2S_MCLK);
  if (!i2s.begin(I2S_MODE_STD, 22000, I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_MONO, I2S_STD_SLOT_LEFT)) {
    Serial.println("Failed to initialize I2S!");
    while (1); // do nothing
  if (!i2s.configureRX(22000, I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_MONO, I2S_RX_TRANSFORM_NONE) ){
    Serial.println("Failed to initialize RX Channel!");
 if (!i2s.configureTX(22000, I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_STEREO)) {
    Serial.println("Failed to initialize TX Channel!");
// codec ES8388 init
  Serial.printf("Connect to ES8388 codec... ");
  while (not es.begin(IIC_DATA, IIC_CLK))
      Serial.printf("Failed!\n");
      while(1);
  Serial.printf("OK\n");
// volumes
  es.volume(ES8388::ES_MAIN, volume);
  es.volume(ES8388::ES_OUT1, volume);
  es.mute(ES8388::ES_OUT1, false);
  es.mute(ES8388::ES_MAIN, false);
  es.microphone_volume(microVol);
  es.ALC(false);
  es.Amp_D(true);
void loop() {
#define T 1024
    size_t t;
    char buf[T/2];
    char bufb[T];
    int tb;
    int L;
    if (gpio_get_level(BUTTON_PAUSE) == 0)
    while(gpio_get_level(BUTTON_PAUSE) == 0) delay(10);
    f = SD.open("/record.wav", "w");
    f.seek(PCM_WAV_HEADER_SIZE);   // leave room for the header
    printf("recording...\n");
    L = 0;
    uint8_t M, N;
    while(gpio_get_level(BUTTON_PAUSE) == 1)
     t = i2s.readBytes(buf, T/2);
 // one channel ==> two channels
     for(int i=0;i<t;i=i+2)
      bufb[i+i] = buf[i];
      bufb[i+i+1] = buf[i+1];
      bufb[i+i+2] = buf[i];
      bufb[i+i+3] = buf[i+1];
     f.write((const uint8_t*)bufb, t+t);
     L = L + 2*t;
    f.seek(0);
 // to refresh size values
    H.descriptor_chunk.chunk_size = L + PCM_WAV_HEADER_SIZE ;
    H.data_chunk.subchunk_size = L;
 // write the header
    f.write((uint8_t*)&H, PCM_WAV_HEADER_SIZE);
    f.seek(L + PCM_WAV_HEADER_SIZE);
    f.close();
    printf("playing...\n");
    f = SD.open("/record.wav", "r");
    f.seek(PCM_WAV_HEADER_SIZE);    // skip the header
    do
     tb = f.read((uint8_t*)bufb, T);
     i2s.write((uint8_t*)bufb, (size_t)tb);
    }while(tb > 0);
    f.close();
    delay(100);
Have you tried to turn on ALC?
Yes, I tried it. It’s not better.
hi, thx we have found a mistake on our side in this example, the library will be updated in a couple days, I will drop you a message here.
Great ! In the meantime, do you have a quick fix ?
I don’t know if it’s related. When I analyze the signal with Audacity, I can see that the signal is very weak and I can’t amplify it.
It’s ready! Update to the latest Arduino Muse Library (1.0.9), then load the example record_internal_mic.
Press the middle button to record 5 seconds of audio, which will be played back from RAM—no SD card needed.
If you have a Luxe V2 (large white marking on the bottom of the speaker), you can use the record_external_mic example, which utilizes a microphone through the TRRS jack, like the hands-free headsets commonly used in the early 2000s.
Thanks for this new version.
However, if I add to the example “record_internal_mic” a wifi connection and I make the recording without the USB cable, there is still a lot of noise.
So you hear no difference??
ok and without wifi and with cable?
With the new library the signal amplification is better.
Without wifi (with or without cable) => ok (no noise)
You don’t observe the same thing ?
Share your code please this will be easier
