Modulox Brain - Quick start guide
Modulox – Quick Start Guide
Modulox Brain
What’s in the Box?
  • 3.5mm jack to MIDI DIN RX-TX + sync cable
  • USB C cable
  • Modulox Brain
Cleaning the Modulox Sticky Base Pad
Use a wet sponge to clean the gecko pad. Allow it to dry for a few minutes and it will stick again!
Loading a New Machine on the Modulox Brain
  1. Connect your Modulox Brain using the USB C cable.
  2. Open a Chrome browser.
  3. Visit https://apps.raspiaudio.com/.
  4. Select “modulox” on the left and choose the machine to load on the right.
Open Source Status
  • Software: All our software is open source and can be ported to any ESP32 S3 device.
    Repository: MODULOX_BRAIN on GitHub
  • Hardware: The hardware is closed source. This helps us pay salaries and develop new software features for the open-source community.
Additional Connections
  • Chaining Modulox Devices:
    How to chain more than one Modulox using the jack sync cable?
    plug TTRS jack 3.5mm “IN” port to a second Modulox “OUT” port
  • Connecting Other Modulox Devices:
    How to connect other Modulox devices using the magnetic connectors?
    Align the magnetic pogo pins connectors fo a good snap.
Machines
1. Granulizer
  • Navigating menu:
    Click on left/right buttons to change menu pages.
    Or click on “menu” button then navigate by turning encoder and right/left to choose the page name in a menu list. If the name in the list starts by an “@” then it’s a page name.
  • Loading a Sample:
    • Direct record on the device.
      Go to “Select Sample” page and click on middle button. The record starts. Click again to stop. The record stops automatically after 8 seconds.
      The sample is stored in the RAM and disappear if you select an other sample or turn off your modulox.
    • USB upload.
Keep pressing left button while plugging USB cable. Repositories will appear on computer. Drag and drop wave samples here.
  • Selecting a Sample
    Go to menu “Select sample” and turn the encoder to change the sample.
  • Connecting a MIDI Keyboard
    Connect the jack-to-MIDI cable to input of modulox, plug the MIDI keyboard and it will work out of the box.
  • Using MIDI Learn
    When you are on a page with a parameter, click on the encoder and you will see a blue screen. Then turn your MIDI CC controller (USB or phisycal MIDI).The CC value will appear on the screen. Click again on the encoder, and it will be mapped.
