Since a few of us have posted in github with zero help from the esphome people, was hoping someone in here may have an idea as to why? Since 2023.4.x the Muse Luxe always shows full volume, you change the volume and it shows in the log but then goes back up to full. The only time you can adjust it is when it’s actually playing something and then when it stops it goes back to full volume.
jmcgeejr:
Ok we will try and let you know soon
Here’s a link to the github issue
opened 02:23PM - 20 Apr 23 UTC
### The problem
Since update to ESPhome 2023.4.0 media players are starting wit… h max volume.
### Which version of ESPHome has the issue?
2023.4.0
### What type of installation are you using?
Home Assistant Add-on
### Which version of Home Assistant has the issue?
2023.4.5
### What platform are you using?
ESP32
### Board
nodemcu
### Component causing the issue
i2s_audio, media_player
### Example YAML snippet
```yaml
i2s_audio:
i2s_lrclk_pin: GPIO25
i2s_bclk_pin: GPIO5
media_player:
- platform: i2s_audio
dac_type: external
i2s_dout_pin: GPIO26
mode: mono
mute_pin:
number: GPIO21
inverted: true
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
mk377
May 8, 2023, 9:57pm
#4
But is it loud now? That would be great.
Deco
May 9, 2023, 5:51am
#5
Put a bigger speaker on and its more than loud, i use a 4ohm 30w and it blast out my bathroom, and i didn’t even use gain
