Since I am not at all familiar with esp32 and adruino.
I tried chatp gpt, gemini and cloud to get something working.
That was at least something that could be compiled but unfortunately it didn’t work.
Introduction
This program is intended to be used with the ESP32 Muse speaker, a portable and affordable bluetooth speaker that is fully programmable.
ESP32 Muse is a commercial product that can be purchase here: https://raspiaudio.com/espmuse
Features
ESP32 offers: line Input, RGB leds
This is a simplified version including only AUX in and LED functions.
#include "Audio.h"
// Standard ESP-IDF driver includes for I2C and GPIO
extern "C"
#include "driver/i2c.h"
#include "driver/gpio.h"
#include "Arduino.h"
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <NeoPixelBus.h>
#define muse 1
// Pin Definitions
#define SDA 18
#define SCL 23
//Contacts
#define PA GPIO_NUM_21 // Amp power ON
#ifdef muse
#define AUXD GPIO_NUM_27 // AUX In detect 27
#else
#define AUXD GPIO_NUM_12
#endif
// I2C Configuration for ES8388 Codec
#define I2C_MASTER_NUM I2C_NUM_0
#define I2C_MASTER_FREQ_HZ 400000
#define I2C_MASTER_TIMEOUT_MS 1000
// Define I2C read/write bits for device address byte (used in hal_i2c_master_mem_write/read)
#define I2C_MASTER_WRITE_BIT I2C_MASTER_WRITE // for writing to slave
#define I2C_MASTER_READ_BIT I2C_MASTER_READ // for reading from slave
// Custom implementations of hal_i2c_master_* functions using ESP-IDF I2C driver API
esp_err_t hal_i2c_master_init(i2c_port_t i2c_num, int sda_io, int scl_io) {
i2c_config_t conf;
conf.mode = I2C_MODE_MASTER;
conf.sda_io_num = sda_io;
conf.scl_io_num = scl_io;
conf.sda_pullup_en = GPIO_PULLUP_ENABLE;
conf.scl_pullup_en = GPIO_PULLUP_ENABLE;
conf.master.clk_speed = I2C_MASTER_FREQ_HZ;
conf.clk_flags = 0; // default clk_flags is 0
esp_err_t ret = i2c_param_config(i2c_num, &conf);
if (ret != ESP_OK) return ret;
return i2c_driver_install(i2c_num, conf.mode, 0, 0, 0);
esp_err_t hal_i2c_master_mem_write(i2c_port_t i2c_num, uint8_t device_address,
uint8_t reg_addr, uint8_t *data, size_t data_len) {
i2c_cmd_handle_t cmd = i2c_cmd_link_create();
i2c_master_start(cmd);
i2c_master_write_byte(cmd, (device_address << 1) | I2C_MASTER_WRITE_BIT, true);
i2c_master_write_byte(cmd, reg_addr, true);
i2c_master_write(cmd, data, data_len, true);
i2c_master_stop(cmd);
esp_err_t ret = i2c_master_cmd_begin(i2c_num, cmd, I2C_MASTER_TIMEOUT_MS / portTICK_PERIOD_MS);
i2c_cmd_link_delete(cmd);
return ret;
esp_err_t hal_i2c_master_mem_read(i2c_port_t i2c_num, uint8_t device_address,
i2c_master_write_byte(cmd, (device_address << 1) | I2C_MASTER_READ_BIT, true);
i2c_master_read(cmd, data, data_len, I2C_MASTER_LAST_NACK);
return ret;
// NeoPixel led control
#define PixelCount 1
#define PixelPin 22
RgbColor RED(255, 0, 0);
RgbColor GREEN(0, 255, 0);
RgbColor BLUE(0, 0, 255);
RgbColor YELLOW(255, 128, 0);
RgbColor WHITE(255, 255, 255);
RgbColor BLACK(0, 0, 0);
NeoPixelBus<NeoGrbFeature, Neo800KbpsMethod> strip(PixelCount, PixelPin);
// init audio library
Audio audio;
#define I2SN (i2s_port_t)0 // Still defined, but not directly used in this simplified I2S-less version
#define maxMode 3
#define btM 0
#define sdM 1
#define auxM 2
#define maxVol 50
uint8_t vauxd;
int vol, oldVol;
bool auxON = false;
bool beepON = false;
uint32_t sampleRate;
int mode = btM; // Declare mode globally and initialize
#define ES8388_ADDR 0x10
// Write ES8388 register (using I2c)
void ES8388_Write_Reg(uint8_t reg, uint8_t val)
uint8_t buf[2];
buf[0] = reg;
buf[1] = val;
hal_i2c_master_mem_write(I2C_MASTER_NUM, ES8388_ADDR, buf[0], buf + 1, 1);
// Read ES8388 register (using I2c)
uint8_t ES8388_Read_Reg( uint8_t reg_add)
uint8_t val;
hal_i2c_master_mem_read(I2C_MASTER_NUM, ES8388_ADDR, reg_add, &val, 1);
return val;
// manages volume (via vol xOUT1, vol DAC, and vol xIN2)
void ES8388vol_Set(uint8_t volx)
#define M maxVol - 33
printf("volume ==> %d\n", volx);
ES8388_Write_Reg(25, 0x00);
if (volx > maxVol) volx = maxVol;
if (volx == 0)
ES8388_Write_Reg(25, 0x04);
if (mode == auxM)
ES8388_Write_Reg(39, 0x80);
ES8388_Write_Reg(42, 0x80);
if (volx >= M)
ES8388_Write_Reg(46, volx - M);
ES8388_Write_Reg(47, volx - M);
ES8388_Write_Reg(26, 0x00);
ES8388_Write_Reg(27, 0x00);
if (mode == auxM)
uint8_t v = ((7 - (volx - M - 3) / 4) << 2) | 0xC0;
ES8388_Write_Reg(39, v);
ES8388_Write_Reg(42, v);
else
ES8388_Write_Reg(46, 0x00);
ES8388_Write_Reg(47, 0x00);
ES8388_Write_Reg(26, (M - volx) * 3);
ES8388_Write_Reg(27, (M - volx) * 3);
// init CCODEC chip ES8388 (via I2C)
void ES8388_Init(void)
// provides MCLK
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO0_CLK_OUT1);
WRITE_PERI_REG(PIN_CTRL, READ_PERI_REG(PIN_CTRL) & 0xFFFFFFF0);
// reset
ES8388_Write_Reg(0, 0x80);
ES8388_Write_Reg(0, 0x00);
// mute
ES8388_Write_Reg(1, 0x50); //powerup
ES8388_Write_Reg(2, 0x00);
// slave mode
ES8388_Write_Reg(8, 0x00);
// DAC powerdown
ES8388_Write_Reg(4, 0xC0);
// vmidsel/500k ADC/DAC idem
ES8388_Write_Reg(0, 0x12);
ES8388_Write_Reg(1, 0x00);
// i2s 16 bits
ES8388_Write_Reg(23, 0x18);
// sample freq 256
ES8388_Write_Reg(24, 0x02);
// LIN2/RIN2 for mixer
ES8388_Write_Reg(38, 0x09);
// left DAC to left mixer
ES8388_Write_Reg(39, 0x90);
// right DAC to right mixer
ES8388_Write_Reg(42, 0x90);
// DACLRC ADCLRC idem
ES8388_Write_Reg(43, 0x80);
ES8388_Write_Reg(45, 0x00);
// DAC volume max
ES8388_Write_Reg(2 , 0xF0);
ES8388_Write_Reg(2 , 0x00);
ES8388_Write_Reg(29, 0x1C); // DAC power-up LOUT1/ROUT1 enabled
ES8388_Write_Reg(4, 0x30);
// unmute
// amp validation
gpio_set_level(PA, 1);
// annonce tiny messages (2-3 sec) (mode name)
void modeCall(void)
#define volMode 50
char*n[] = {"/bluetooth.wav", "/player.wav", "/jack.wav"};
ES8388vol_Set(volMode);
printf("%d ====> %s\n", mode, n[mode]);
// Removed playWav calls as they require SPIFFS and WAV files which are not part of AUX/LED
beepON = false;
ES8388vol_Set(vol);
// i2s_set_clk is commented out or missing definition in simplified version
// If it's necessary for operation, consider how to include it or its equivalent
// i2s_set_clk(I2SN, sampleRate, (i2s_bits_per_sample_t)16, (i2s_channel_t)2);
// task managing analog input via AUXIn jack
static void aux (void* data)
delay(500);
ES8388_Write_Reg(39, 0xC0);
ES8388_Write_Reg(42, 0xC0);
ES8388vol_Set(45);
while (1) {
delay(100);
if (mode != auxM) {
auxON = 0;
vTaskDelete(NULL);
// Check for AUX cable connection (example, requires GPIO setup for AUXD)
vauxd = gpio_get_level(AUXD);
if ((vauxd == 0) && (auxON == false)) {
auxON = true;
mode = auxM;
modeCall();
if ((vauxd == 1) && (auxON == true)) {
auxON = false;
mode = btM; // Default to BT mode if AUX is disconnected
modeCall();
void setup() {
Serial.begin(115999);
Serial.println("ESP32 Muse Speaker - AUX and LED only version");
// Init LEDs
strip.Begin();
strip.Show(); // Initialize all pixels to 'off'
// Initialize I2C for ES8388 codec
hal_i2c_master_init(I2C_MASTER_NUM, SDA, SCL);
ES8388_Init(); // Initialize the audio codec
// Set initial volume
vol = 30; // Default volume
ES8388vol_Set(vol);
// Configure AUX detection pin
gpio_set_direction(AUXD, GPIO_MODE_INPUT);
// Start AUX task
xTaskCreatePinnedToCore(aux, "aux", 40000, NULL, 10, NULL, 1);
// Initial LED color
strip.SetPixelColor(0, BLUE);
strip.Show();
void loop() {
// Example: Change LED color based on mode
if (mode == auxM) {
strip.SetPixelColor(0, GREEN); // Green for AUX mode
} else {
strip.SetPixelColor(0, BLACK); // Off when not in AUX mode
strip.Show();
// Basic volume control (example, needs physical buttons to be implemented)
// For simplicity, this example doesn't include button handling
// You would read button states here and adjust 'vol' then call ES8388vol_Set(vol);
delay(500); // Small delay
