I have a similar issue to dxdy and rrteigeiro’s original posts. I have purchased 2 x Luxe speakers. One of them was bricked after flashing it a few times with different packages and hard resetting didn’t work. It was replaced by Amazon.
The replacement now operates fine - almost. I’ve flashed it once with media software here Ready-Made Projects — ESPHome and integrated with Home Assistant but after a short while it drops offline and doesn’t come back.
Numerous attempts at the on/off button doesn’t work. If I use the on/off button a few times with the USB link cable connected for logs then sometimes I can get it to start.
Sometimes when it starts the speaker makes a pulsating, repeating on/off ‘static noise’ sound.
Any thoughts would be appreciated. Thanks.
Log excerpt
INFO Reading configuration /config/esphome/raspiaudio-muse-luxe-20cd8c.yaml...
INFO Updating https://github.com/esphome/esphome.git@pull/3552/head
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
INFO Starting log output from 192.168.1.179 using esphome API
INFO Successfully connected to raspiaudio-muse-luxe-20cd8c @ 192.168.1.179 in 0.062s
INFO Successful handshake with raspiaudio-muse-luxe-20cd8c @ 192.168.1.179 in 0.100s
[21:00:31][I][app:100]: ESPHome version 2024.4.2 compiled on May 1 2024, 20:48:14
[21:00:31][I][app:102]: Project raspiaudio.muse-luxe version 1.0
[21:00:31][C][wifi:580]: WiFi:
[21:00:31][C][wifi:408]: Local MAC: AC:0B:FB:20:CD:8C
[21:00:31][C][wifi:413]: SSID: 'TheTrueSource'[redacted]
[21:00:31][C][wifi:416]: IP Address: 192.168.1.179
[21:00:31][C][wifi:420]: BSSID: 14:EB:B6:6F:E0:76[redacted]
[21:00:31][C][wifi:421]: Hostname: 'raspiaudio-muse-luxe-20cd8c'
[21:00:31][C][wifi:423]: Signal strength: -47 dB ▂▄▆█
[21:00:31][C][wifi:427]: Channel: 10
[21:00:31][C][wifi:428]: Subnet: 255.255.255.0
[21:00:31][C][wifi:429]: Gateway: 192.168.1.1
[21:00:31][C][wifi:430]: DNS1: 8.8.8.8
[21:00:31][C][wifi:431]: DNS2: 0.0.0.0
[21:00:31][C][logger:166]: Logger:
[21:00:31][C][logger:167]: Level: DEBUG
[21:00:31][C][logger:169]: Log Baud Rate: 115200
[21:00:31][C][logger:170]: Hardware UART: UART0
[21:00:31][C][i2c.arduino:071]: I2C Bus:
[21:00:31][C][i2c.arduino:072]: SDA Pin: GPIO18
[21:00:31][C][i2c.arduino:073]: SCL Pin: GPIO23
[21:00:31][C][i2c.arduino:074]: Frequency: 50000 Hz
[21:00:31][C][i2c.arduino:086]: Recovery: bus successfully recovered
[21:00:31][I][i2c.arduino:096]: Results from i2c bus scan:
[21:00:31][I][i2c.arduino:102]: Found i2c device at address 0x10
[21:00:31][I][i2c.arduino:102]: Found i2c device at address 0x75
[21:00:31][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Volume Up'
[21:00:31][C][gpio.binary_sensor:016]: Pin: GPIO19
[21:00:31][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Volume Down'
[21:00:31][C][gpio.binary_sensor:016]: Pin: GPIO32
[21:00:31][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Action'
[21:00:31][C][gpio.binary_sensor:016]: Pin: GPIO12
[21:00:31][C][fastled:021]: FastLED light:
[21:00:31][C][fastled:022]: Num LEDs: 1
[21:00:31][C][fastled:023]: Max refresh rate: 400
[21:00:31][C][light:103]: Light 'RaspiAudio Muse Luxe 20cd8c'
[21:00:31][C][light:105]: Default Transition Length: 1.0s
[21:00:31][C][light:106]: Gamma Correct: 2.80
[21:00:31][C][adc:097]: ADC Sensor 'Battery'
[21:00:31][C][adc:097]: Device Class: 'voltage'
[21:00:31][C][adc:097]: State Class: 'measurement'
[21:00:31][C][adc:097]: Unit of Measurement: 'V'
[21:00:31][C][adc:097]: Accuracy Decimals: 3
[21:00:31][C][adc:097]: Icon: 'mdi:battery-outline'
[21:00:31][C][adc:107]: Pin: GPIO33
[21:00:31][C][adc:122]: Attenuation: 11db
[21:00:31][C][adc:142]: Update Interval: 15.0s
[21:00:31][C][captive_portal:088]: Captive Portal:
[21:00:31][C][mdns:115]: mDNS:
[21:00:31][C][mdns:116]: Hostname: raspiaudio-muse-luxe-20cd8c
[21:00:31][C][ota:096]: Over-The-Air Updates:
[21:00:31][C][ota:097]: Address: 192.168.1.179:3232
[21:00:31][C][ota:100]: Using Password.
[21:00:31][C][ota:103]: OTA version: 2.
[21:00:31][C][api:139]: API Server:
[21:00:31][C][api:140]: Address: 192.168.1.179:6053
[21:00:31][C][api:142]: Using noise encryption: YES
[21:00:31][C][improv_serial:032]: Improv Serial:
[21:00:31][C][audio:203]: Audio:
[21:00:31][C][audio:225]: External DAC channels: 2
[21:00:31][C][audio:226]: I2S DOUT Pin: 26
[21:00:31][C][audio:227]: Mute Pin: GPIO21
[21:00:46][D][sensor:094]: 'Battery': Sending state 3.83510 V with 3 decimals of accuracy
...[gap inserted by me]
[21:26:46][D][sensor:094]: 'Battery': Sending state 3.42063 V with 3 decimals of accuracy
[21:27:16][D][sensor:094]: 'Battery': Sending state 3.39637 V with 3 decimals of accuracy
[21:27:46][D][sensor:094]: 'Battery': Sending state 3.37555 V with 3 decimals of accuracy
[21:28:16][D][sensor:094]: 'Battery': Sending state 3.35027 V with 3 decimals of accuracy
[21:28:46][D][sensor:094]: 'Battery': Sending state 3.32942 V with 3 decimals of accuracy
[21:29:16][D][sensor:094]: 'Battery': Sending state 3.29953 V with 3 decimals of accuracy
[21:29:46][D][sensor:094]: 'Battery': Sending state 3.25737 V with 3 decimals of accuracy
[21:30:16][D][sensor:094]: 'Battery': Sending state 3.22057 V with 3 decimals of accuracy
[21:30:46][D][sensor:094]: 'Battery': Sending state 3.18910 V with 3 decimals of accuracy
[21:31:16][D][sensor:094]: 'Battery': Sending state 3.16123 V with 3 decimals of accuracy
[21:31:46][D][sensor:094]: 'Battery': Sending state 3.13227 V with 3 decimals of accuracy
[21:32:16][D][sensor:094]: 'Battery': Sending state 3.10448 V with 3 decimals of accuracy
WARNING raspiaudio-muse-luxe-20cd8c @ 192.168.1.179: Connection error occurred: Ping response not received after 90.0 seconds
INFO Processing unexpected disconnect from ESPHome API for raspiaudio-muse-luxe-20cd8c @ 192.168.1.179
WARNING Disconnected from API
WARNING Can't connect to ESPHome API for raspiaudio-muse-luxe-20cd8c @ 192.168.1.179: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.179', port=6053))]: [Errno 113] Connect call failed ('192.168.1.179', 6053) (SocketAPIError)
INFO Trying to connect to raspiaudio-muse-luxe-20cd8c @ 192.168.1.179 in the background
