This is a quick tutorial to burn a precomplied bin file of SqueezeLite on the ESPMUSE LUXE SPEAKER to do multiroom audio and more. This tutorial below is updated with the latest files version and tries to summarize this long thread below.
Updated 09/05/22: Method 1 (preferred)
there is a new very easy way to install Squeezlite in to the Muse (Luxe or Proto) from a Chrome browser without the need to install anything.
This as been implemented by Paulus Schoutsen creator of Home Assistant.
Method 2:
It is sometime difficult to start with Squeeze Light so I have made a pre-confirgured .bin file to burn on the ESPMUSE LUXE SPEAKER you can download the latest bin file here
Edit: Once you have downloaded the Raspiaudio cooked firmware of Squeezelite above you will be able to do an OTA update using the web interface by choosing the Luxe firmware. This is thanks to the integration of the Luxe by Philippe44 in the main branch of his project
What can you do with it?
Multiroom is great at home when you want to have the same music synchronized in you living room, kitchen, bathroom without the need of moving a bluetooth speaker and a phone with you, or worst having a very loud distorted music in one room hoping to hear in every room.
Squeezelite-esp32 is an audio software suite made to run on espressif’s ESP32 wifi (b/g/n) and bluetooth chipset. It offers the following capabilities
- Stream your local music and connect to all major on-line music providers (Spotify, Deezer, Tidal, Qobuz) using Logitech Media Server - a.k.a LMS and enjoy multi-room audio synchronization. LMS can be extended by numerous plugins and can be controlled using a Web browser or dedicated applications (iPhone, Android). It can also send audio to UPnP, Sonos, ChromeCast and AirPlay speakers/devices.*
- Stream from a Bluetooth device (iPhone, Android)*
- Stream from an AirPlay controller (iPhone, iTunes …) and enjoy synchronization multiroom as well (although it’s AirPlay 1 only)*
How to load Squeezelite on the MUSE SPEAKER?
The cable coming with the LUXE is for charge only, use a micro USB data cable instead
-With Linux or ESPTOOLS use the following command :
esptool.py -p /dev/ttyUSB0 write_flash 0x0 my_image_to_burn.bin
-With Microsoft Windows, It must be loaded using the ESP32 flash downloading tool :
https://www.espressif.com/sites/default/files/tools/flash_download_tool_3.9.2.zip
Unzip it and execute
Choose Developer Mode / ESP32 :
Select the path of the previously downloaded .bin file and set the loading address to “0x0” (select the check box on the left):
Connect the RASPIAUDIO MUSE via USB at the bottom select the right com port used by the connected board:
This com port number could change so if you are not sure of the com port go in windows 10 go to Device Manager and in the port section look for the number used by Silicon Lab. If you don’t see the com port you might have to install the drivers manually here
Check that the switch is ON position on the back of the speaker
Click on START, it should now take 3mn to load:
Then reboot your MUSE turn it of for 5s and turn it on again, and Squeezlite should start, connect to your new audio bluetooth device on a phone or computer you should have a new device called “ESP-32-*****”, connect to it and play.
To really have fun
To enable Airplay and Logitech Media Server you need to set the wifi connection. By default when no credential is setup an access point is created called “muse”, connect to it password is “musemuse”. Using a browser go to 192.168.4.1 then in the wifi section find you network and enter your wifi password. reboot.
Allows you to stream content thru a local server, and many cool stuff lik sync several devices for multi rooms audio.
Install the server on your PC, then your squeezelite device(s) should be found if on the same network, and could be sync :
Airplay
Out of the box
To Do
- For now you can’t upgrade using the web interface
The buttons are not very resposive to change the volume you have to push and release quickly
- It seems that if the Luxe is left OFF for a long time and not connected to USB (>12h not confirmed) the device deos not start anymore unless put to charge. under investigation.
- Need to qualify the real autonomy of a full charged battery.
How to compile the code ?
Our forked GIT version of squeezelite is here what we do in this fork is to add the audio codec that is used in the LUXE. In the future the goal is to ask to the orginal creator of the main branch of squeezligth to merge with our version so we will be able to follow updates easily. All credits for that project goes to the original creators Sle118 and Philippe44.
Similar to the Luxe but more DIY
there is also a tutorial for ESPMUSE PROTO here the small mono version of the LUXE without the case and speaker.
