Muse Luxe with ESPHome audio drop out
It has the latest firmware. It was discovered fast on ESPhome after firmware upgrade. It worked fine right away too. I’ve added it as an official speaker in music assistant.
The issue I’m having is that after like 6-8 hours the audio doesn’t play out of it. It shows like it’s still registered in ESPhome. I can turn on and off the LED on top of it through HA, but when I play audio it says it is but it’s not. The only thing that works is turning it on and off then it works again, for a few hours.
Any suggestions?
Hi, let me try the same in music assistant, and come back to you.
ESP Home released many feature a few days ago that will make our life easier so we will integrate it soon:
Thank you. It’s doing it again. If I let it sit idle for a few hours or a day, when I try to send audio it just clicks once, says it’s playing, and no audio comes out.
Hello Raspiaudio, do you have a working version for Muse Luxe yet? It stopped working for me about 14 days ago and it says this message. Thank you and greetings!
INFO ESPHome 2025.2.1
INFO Reading configuration /config/esphome/raspiaudio-muse-luxe-28474c.yaml…
Failed config
packages: [source /config/esphome/raspiaudio-muse-luxe-28474c.yaml:5]
not a valid value.
raspiaudio.muse-luxe: media-player/raspiaudio-muse-luxe.yaml
it’s the next one on the list, I keep you posted
Perfect, thanks for the message, I’ll wait!
I’m still having the same issues. It produces no audio except a clicking noise. It appears to be still registered and I can access all functions except it produces no audio. If I reboot the speaker, it will work for an hour or 2 then goes back to no audio.
as i said a few hour ago we are working on it, not a bug just a major Home Asssistant release
Thank you. Thought you were referring to the other person’s particular issue.
