Hi, I just installed a new device from here: https://raspiaudio.github.io/ without configuring anything else.
When I listen to music or radio stream with my LMS, it sounds crashy. Like the signal on the analog jack output is to high?
Do i have to configure something, switch from Headphones to “line out” or something like this? THX
Hello and welcome!
Could you try to install a simpler app to check if this is an hardware issue or not. Form apps.raspiaudio.com try MNcast-Bluetooth
then connect in bluetooth with your phone and check if you have the same issue.
Hi, the HW is ok, with the simple player it wors fine ![]()
THX
