Muse proto plays audio slower
Hi everyone
Using the Muse proto with Home Assistant via WiFi to play an audio file after a doorbell press.
Since a while the audio plays at a slower tempo and is sometimes stuttered.
Anyone with tips for a cause/solution?
Thanks and best regards
OWK
hi can you detail the yaml and automation that you are using?
HI,
Here it is:
ESP32
esphome:
esp32:
board: esp-wrover-kit
framework:
type: arduino
i2s_audio:
i2s_lrclk_pin: GPIO25
i2s_bclk_pin: GPIO5
media_player:
  • platform: i2s_audio
    name: raspiaudio-muse-proto-d40a44 #${name} player ESPHome I2S Media Player
    dac_type: external
    i2s_dout_pin: GPIO26
    mode: mono
    mute_pin:
    number: GPIO21
    inverted: true
Enable logging
logger:
Enable Home Assistant API
api:
ota:
platform: esphome
wifi:
ssid: !secret wifi_ssid
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “-”
password: “-”
captive_portal:
Home Assistant:
action:
  • service: media_player.play_media
    target:
    entity_id: media_player.raspiaudio_muse_proto_d40a44
    data:
    media_content_id: media-source://media_source/local/audio/DasGlockenspiel.wav
    media_content_type: audio/x-wav
