Muse Radio Home Assistant
Just installed the new firmware, this is great - sound quality seems much better now.
Is it correct though that the voice assistant functionality is unavailable if music is being played? Suggestion would be to use the Ok/Confirm button on the player to pause music and trigger wake word.
@SeByDocKy - I want to implement the same functionality; can you propose a PR to github so this can be implemented in the main version?
As a side note, I would recommend installing Music Assistant if not done so already. Latest version provides easy integration of Spotify Connect for any speaker including ESP based ones.
FIY I did the yaml modification to setup through HA front-end the 4 radio presets. Seems to work fine…
It’s here : myESPhome/code/radio-microWW.yaml at main Ā· SeByDocKy/myESPhome Ā· GitHub
We have exciting updates check our demo and tuorial here:
-Improved relabily
-Impoved local wake word detection
-New screens
upper encoder push: mute/unmute
lower encoder push: Wake word mode / start a conversation mode (no wake word)
Muse Radio Home Assistant New Version
A new version has just been released: 2025.3.0
featuring:
  • battery management support
  • improved display
  • headphone listening support (jack detect)
  • fixes for some minor bugs
Hi, thanks for all the updates. 3.0 works like a charm!
I noticed a new version, 3.1 - is assumption correct it enables ir?
A new version of Muse Radio Home Assistant is now available(2025.3.1)
It offers two new features:
  • Persistant audio volume
    - Audio volume is retained after a restart.
  • Remote control support
    - with 4 assigned buttons (Volume Up, Volume Down, Mute, Back)
    - and 8 buttons available for automations
Let me know what you think!
(Another version is in development…)
As announced, a new version is available (2025.3.2).
In addition to fixing various minor issues, it includes improved Wi-Fi management, which greatly enhances the radio’s startup process.
I welcome all your feedback on this version and any suggestions for further improvements…
See you soon!
I’m very new at this, sorry if the answer to this question is obvious.
I would like to use my Muse Radio as both a voice assistant and as a sendspin multi room speaker. I found this fork which I assume would do the trick? But how do I proceed to install a fork on my Muse Radio?
This version is somewhat outdated; it will be replaced in a few days by a more comprehensive version tailored for Home Assistant and Music Assistant.
In the meantime, you might want to check out RASPIAUDIO/esphomeRadioMusic; it is very recent but supports only Music Assistant (and therefore sendspin).
You can download this version:
That is awesome news. Thank you for letting me know!
