Newbie question about battery power
As a newbie, I’m a little embarrassed to ask, but I can’t seem to get the MUSE PROTO (ver. 1.7) to work with 18650 battery.
I’ve managed to find the PH2.0 connector and solder the wires to to the cells, which are connected in parallel.
I don’t think the board is fried (yet), because when I plug the usb-c cable in, the board still starts.
What could be the problem here?
Thanks for your reply.
Do you have a voltmeter to confirm that you have between 3v to 4.2v coming out your cells?
Yes, Sir. And it’s happening to both boards I purchased.Video
remove your battery pack, plug the USB C, do you measure 4.2V on the onboard battery connector?
Yes, I do.
Video
Again, same result for both of my boards.
Looking at it now check your private messages in 24h please
Got the message. Thanks for debugging it.
