I flashed my device the following website https://esphome.github.io/media-players/
I select Muse and the flashing process worked well. After connecting to my WiFi I start adding the device to Home Assistant.
All seems fine but if I try to play an audio wav file there is only a scratchy noise.
If I select the muse device in Home Assistant I got the following information:
Firmware: 2022.8.3 (Sep 7 2022, 01:29:31)
Hardware: 1.0
In the log I see the following:
[I][app:062]: setup() finished successfully!
[I][app:102]: ESPHome version 2022.8.3 compiled on Sep 7 2022, 01:29:31
[I][app:104]: Project raspiaudio.muse-luxe version 1.0
[C][wifi:491]: WiFi:
[C][wifi:353]: Local MAC: 94:B5:55:39:A3:98
[C][wifi:354]: SSID: [redacted]
[C][wifi:355]: IP Address: 192.168.111.160
[C][wifi:357]: BSSID: [redacted]
[C][wifi:358]: Hostname: ‘raspiaudio-muse-luxe-39a398’
[C][wifi:360]: Signal strength: -53 dB ▂▄▆█
[C][wifi:364]: Channel: 5
[C][wifi:365]: Subnet: 255.255.255.0
[C][wifi:366]: Gateway: 192.168.111.1
[C][wifi:367]: DNS1: 192.168.111.4
[C][wifi:368]: DNS2: 0.0.0.0
[C][logger:275]: Logger:
[C][logger:276]: Level: DEBUG
[C][logger:277]: Log Baud Rate: 115200
[C][logger:278]: Hardware UART: UART0
[C][i2c.arduino:038]: I2C Bus:
[C][i2c.arduino:039]: SDA Pin: GPIO18
[C][i2c.arduino:040]: SCL Pin: GPIO23
[C][i2c.arduino:041]: Frequency: 50000 Hz
[C][i2c.arduino:044]: Recovery: bus successfully recovered
[I][i2c.arduino:054]: Results from i2c bus scan:
[I][i2c.arduino:060]: Found i2c device at address 0x10
[C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘RaspiAudio Muse Luxe Volume Up’
[C][gpio.binary_sensor:016]: Pin: GPIO19
[C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘RaspiAudio Muse Luxe Volume Down’
[C][gpio.binary_sensor:016]: Pin: GPIO32
[C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘RaspiAudio Muse Luxe Play Button’
[C][gpio.binary_sensor:016]: Pin: GPIO12
[C][fastled:021]: FastLED light:
[C][fastled:022]: Num LEDs: 1
[C][fastled:023]: Max refresh rate: 400
[C][light:104]: Light ‘RaspiAudio Muse Luxe’
[C][light:106]: Default Transition Length: 1.0s
[C][light:107]: Gamma Correct: 2.80
[C][captive_portal:088]: Captive Portal:
[C][mdns:094]: mDNS:
[C][mdns:095]: Hostname: raspiaudio-muse-luxe-39a398
[C][ota:085]: Over-The-Air Updates:
[C][ota:086]: Address: raspiaudio-muse-luxe.local:3232
[C][api:138]: API Server:
[C][api:139]: Address: raspiaudio-muse-luxe.local:6053
[C][api:143]: Using noise encryption: NO
[C][improv_serial:032]: Improv Serial:
[C][audio:135]: Audio:
[D][api:102]: Accepted ::FFFF:C0A8:6F08
[D][api.connection:861]: Home Assistant 2022.9.4 (::FFFF:C0A8:6F08): Connected successfully
[D][media_player:059]: ‘RaspiAudio Muse Luxe’ - Setting
[D][media_player:066]: Media URL: https://homeassistant_xxxxx.duckdns.org/media/local/piano2.wav?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI0N2JjNTEzMDJmZjI0YzYyODg5ODVmZTAyMjRlOGY5ZCIsInBhdGgiOiIvbWVkaWEvbG9jYWwvcGlhbm8yLndhdiIsInBhcmFtcyI6e30sImlhdCI6MTY2MzcwODM1MiwiZXhwIjoxNjYzNzk0NzUyfQ.vXgShVLL0Kzddd7mmNJl94YLMRW1xC6urelXxtyCAp0
E (127944) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (127944) task_wdt: - loopTask (CPU 1)
E (127944) task_wdt: Tasks currently running:
E (127944) task_wdt: CPU 0: IDLE0
E (127944) task_wdt: CPU 1: IDLE1
E (127944) task_wdt: Aborting.
abort() was called at PC 0x4016a100 on core 0
ELF file SHA256: 0000000000000000
Backtrace: 0x400897ec:0x3ffbf8a0 0x40089a69:0x3ffbf8c0 0x4016a100:0x3ffbf8e0 0x40087e2d:0x3ffbf900 0x401a388f:0x3ffbc160 0x4016ba0b:0x3ffbc180 0x4008cce9:0x3ffbc1a0 0x4008b52a:0x3ffbc1c0
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
[I][logger:243]: Log initialized
[C][ota:461]: There have been 1 suspected unsuccessful boot attempts.
[D][esp32.preferences:113]: Saving 1 preferences to flash...
[D][esp32.preferences:142]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[I][i2c.arduino:161]: Performing I2C bus recovery
[D][binary_sensor:034]: 'RaspiAudio Muse Luxe Volume Up': Sending initial state OFF
[D][binary_sensor:034]: 'RaspiAudio Muse Luxe Volume Down': Sending initial state OFF
[D][binary_sensor:034]: 'RaspiAudio Muse Luxe Play Button': Sending initial state OFF
[C][fastled:012]: Setting up FastLED light...
[C][light:036]: Setting up light 'RaspiAudio Muse Luxe'...
[D][light:035]: 'RaspiAudio Muse Luxe' Setting:
[D][light:040]: Color mode: RGB
[D][light:050]: Brightness: 100%
[D][light:054]: Color brightness: 100%
[D][light:058]: Red: 100%, Green: 100%, Blue: 100%
[C][wifi:037]: Setting up WiFi...
[D][wifi:046]: Loaded saved wifi settings: WLAN-Speedy
[D][wifi:373]: Starting scan...
[D][esp32.preferences:142]: Saving 1 preferences to flash: 1 cached, 0 written, 0 failed
[D][wifi:388]: Found networks:
[I][wifi:432]: - 'WLAN-Speedy' [redacted]▂▄▆█
[D][wifi:433]: Channel: 5
[D][wifi:434]: RSSI: -52 dB
[D][wifi:433]: Channel: 1
[D][wifi:434]: RSSI: -87 dB
Any ideas?
Maybe an other version to flash?
Kindly regards
Herb Guy
