Problem flashing Muse Luxe v2
Hi - I have recently received my Muse Luxe v2 and wanted to flash for use as a voice assistant with Home Assistant. I followed the instructions as per this page using Chrome on Ubuntu, but unfortunately somewhere in the process something went wrong and the muse does not boot anymore. When booting normally, I get the following messages from the serial connection, after which it immediately reboots:
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:7112
load:0x40078000,len:15624
load:0x40080400,len:4
load:0x40080404,len:3876
entry 0x4008064c
[0;32mI (56) boot: ESP-IDF 5.1.5 2nd stage bootloader[0m
[0;32mI (57) boot: compile time Apr  2 2025 12:29:42[0m
[0;32mI (57) boot: Multicore bootloader[0m
[0;32mI (61) boot: chip revision: v3.1[0m
[0;32mI (65) boot.esp32: SPI Speed      : 40MHz[0m
[0;32mI (70) boot.esp32: SPI Mode       : DIO[0m
[0;32mI (74) boot.esp32: SPI Flash Size : 8MB[0m
[0;32mI (79) boot: Enabling RNG early entropy source...[0m
[0;32mI (84) boot: Partition Table:[0m
[0;32mI (88) boot: ## Label            Usage          Type ST Offset   Length[0m
[0;32mI (95) boot:  0 otadata          OTA data         01 00 00009000 00002000[0m
[0;32mI (103) boot:  1 phy_init         RF data          01 01 0000b000 00001000[0m
[0;32mI (110) boot:  2 app0             OTA app          00 10 00010000 001c0000[0m
[0;32mI (118) boot:  3 app1             OTA app          00 11 001d0000 001c0000[0m
[0;32mI (125) boot:  4 nvs              WiFi data        01 02 00390000 0006d000[0m
[0;32mI (133) boot: End of partition table[0m
[0;32mI (137) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=5fb34h (391988) map[0m
[0;31mE (287) esp_image: invalid segment length 0xffffffff[0m
[0;31mE (287) boot: OTA app partition slot 0 is not bootable[0m
[0;31mE (288) esp_image: image at 0x1d0000 has invalid magic byte (nothing flashed here?)[0m
[0;31mE (296) boot: OTA app partition slot 1 is not bootable[0m
[0;31mE (302) boot: No bootable app partitions in the partition table[0m
ets Jul 29 2019 12:21:46
entry 0x4008064c
When booting and pushing the “hidden” button in the 3.5 jack to get it into download mode, I get the following messages repeatedly every second or so, and using esptool or esphome to erase or flash fails.
rst:0x7 (TG0WDT_SYS_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
Using esptool to erase the flash gives the following:
esptool.py --chip esp32 --port /dev/ttyUSB1 --no-stub erase_flash
esptool.py v4.8.1
Serial port /dev/ttyUSB1
Connecting.....
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: d4:8c:49:c9:c3:c8
Enabling default SPI flash mode...
A fatal error occurred: Invalid head of packet (0x65): Possible serial noise or corruption.
I tried soldering/connecting RX, TX, IO0, IO2 and EN (currently without a 1uF capacitor to GND) on a breadboard using an FT232H but also this does not work and gives the same messages as above. Any suggestions how to fix this?
Kind regards,
Joost van de Wiel
Sorry but because the enclosure was opened and wires were soldered before contacting us, the unit is no longer under warranty, so we can’t replace it.
you can try to reflash it with apps.raspiaudio.com
if it can’t be detected : OFF -hold the hidden button- ON then try again to flashit
Installing Home Assistant on a Raspiaudio Muse Lux results in the error "
E (1734) spi_flash: Detected size(4096k) smaller than the size in the binary image header(8192k). Probe failed.
" The device reboots and produces the same error over and over again.
See https://github.com/RASPIAUDIO/esphomeLuxe/issues/5#issuecomment-2802556559
problem identified "Detected size(4096k) smaller than the size in the binary image header(8192k). "
Fix will be provided later today.
PS: not related with jvandewiel issue
Hi Gatonero!
a new release of luxe_microWW.bin is available (esphomeLuxe)
It should fix your problem…
Please keep me informed
LR
Hello sbar,
I successfully completed the new installation. After the installation, I expected to be asked about the WiFi network, but that didn’t happen. How can I now connect my Muse Lux to my WiFi network?
After some resets i could download the log. Here it is: (sorry that I can’t ubloud a text file)
[D][sensor:093]: ‘Battery voltage’: Sending state 4.58905 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery’: Sending state 100.00000 % with 0 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.58350 V with 2 decimals of accuracy
[I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[D][esp32.preferences:114]: Saving 1 preferences to flash…
[D][esp32.preferences:142]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[D][sensor:093]: ‘Battery voltage’: Sending state 4.60417 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.61716 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.62834 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.63383 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.62215 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.61795 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.58865 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.57486 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.56019 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.56735 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.58512 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.56700 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.55061 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.52206 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery’: Sending state 99.78517 % with 0 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.52408 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.54368 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.56837 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.58458 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.57169 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.56576 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.56988 V with 2 decimals of accuracy
[D][sensor:093]: ‘Battery voltage’: Sending state 4.58610 V with 2 decimals of accuracy
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
entry 0x4008064c
I (28) boot: ESP-IDF 5.1.5 2nd stage bootloader
I (28) boot: compile time Mar 17 2025 12:03:54
I (29) boot: Multicore bootloader
I (32) boot: chip revision: v1.0
I (36) boot.esp32: SPI Speed : 40MHz
I (41) boot.esp32: SPI Mode : DIO
I (45) boot.esp32: SPI Flash Size : 4MB
I (50) boot: Enabling RNG early entropy source…
I (55) boot: Partition Table:
I (59) boot: ## Label Usage Type ST Offset Length
I (66) boot: 0 otadata OTA data 01 00 00009000 00002000
I (74) boot: 1 phy_init RF data 01 01 0000b000 00001000
I (81) boot: 2 app0 OTA app 00 10 00010000 001c0000
I (89) boot: 3 app1 OTA app 00 11 001d0000 001c0000
I (96) boot: 4 nvs WiFi data 01 02 00390000 0006d000
I (104) boot: End of partition table
I (108) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=5e744h (386884) map
I (256) esp_image: segment 1: paddr=0006e76c vaddr=3ffb0000 size=018ach ( 6316) load
I (259) esp_image: segment 2: paddr=00070020 vaddr=400d0020 size=f5ec0h (1007296) map
I (626) esp_image: segment 3: paddr=00165ee8 vaddr=3ffb18ac size=02368h ( 9064) load
I (629) esp_image: segment 4: paddr=00168258 vaddr=40080000 size=19ce4h (105700) load
I (688) boot: Loaded app from partition at offset 0x10000
I (688) boot: Disabling RNG early entropy source…
I (700) cpu_start: Multicore app
I (701) quad_psram: This chip is ESP32-D0WD
I (701) esp_psram: Found 8MB PSRAM device
I (702) esp_psram: Speed: 40MHz
I (706) esp_psram: PSRAM initialized, cache is in low/high (2-core) mode.
W (713) esp_psram: Virtual address not enough for PSRAM, map as much as we can. 4MB is mapped
I (722) cpu_start: Pro cpu up.
I (726) cpu_start: Starting app cpu, entry point is 0x40082a68
I (0) cpu_start: App cpu up.
I (1609) esp_psram: SPI SRAM memory test OK
I (1617) cpu_start: Pro cpu start user code
I (1617) cpu_start: cpu freq: 160000000 Hz
I (1617) cpu_start: Application information:
I (1620) cpu_start: Project name: muse-luxe
I (1625) cpu_start: App version: 2025.2.2
I (1630) cpu_start: Compile time: Mar 17 2025 12:03:11
I (1637) cpu_start: ELF file SHA256: dabc3c7a4b4fa903…
I (1643) cpu_start: ESP-IDF: 5.1.5
I (1648) cpu_start: Min chip rev: v0.0
I (1652) cpu_start: Max chip rev: v3.99
I (1657) cpu_start: Chip rev: v1.0
I (1662) heap_init: Initializing. RAM available for dynamic allocation:
I (1670) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1676) heap_init: At 3FFB8B58 len 000274A8 (157 KiB): DRAM
I (1682) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1688) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1695) heap_init: At 40099CE4 len 0000631C (24 KiB): IRAM
I (1702) esp_psram: Adding pool of 4096K of PSRAM memory to heap allocator
I (1710) spi_flash: detected chip: gd
I (1713) spi_flash: flash io: dio
W (1717) i2s(legacy): legacy i2s driver is deprecated, please migrate to use driver/i2s_std.h, driver/i2s_pdm.h or driver/i2s_tdm.h
W (1729) ADC: legacy driver is deprecated, please migrate to esp_adc/adc_oneshot.h
I (1739) app_start: Starting scheduler on CPU0
I (1743) app_start: Starting scheduler on CPU1
I (1743) main_task: Started on CPU0
I (1753) main_task: Calling app_main()
I (1926) main_task: Returned from app_main()
[I][logger:171]: Log initialized
[C][safe_mode:079]: There have been 0 suspected unsuccessful boot attempts
[I][app:029]: Running through setup()…
[C][i2c.idf:017]: Setting up I2C bus…
[I][i2c.idf:256]: Performing I2C bus recovery
[D][esp-idf:000]: I (1944) gpio: GPIO[23]| InputEn: 1| OutputEn: 1| OpenDrain: 1| Pullup: 1| Pulldown: 0| Intr:0
[D][esp-idf:000]: I (1961) gpio: GPIO[18]| InputEn: 1| OutputEn: 1| OpenDrain: 1| Pullup: 1| Pulldown: 0| Intr:0
[D][esp-idf:000]: I (1996) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
[C][esp32_rmt_led_strip:025]: Setting up ESP32 LED Strip…
[D][esp-idf:000]: I (1998) gpio: GPIO[22]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
[D][esp-idf:000]: I (1999) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
[D][binary_sensor:034]: ‘Volume Up’: Sending initial state OFF
[D][esp-idf:000]: I (2017) gpio: GPIO[32]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
[D][binary_sensor:034]: ‘Volume Down’: Sending initial state OFF
[D][esp-idf:000]: I (2037) gpio: GPIO[12]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
[D][binary_sensor:034]: ‘Mute’: Sending initial state OFF
[C][light:021]: Setting up light ‘Raspiaudio Muse Luxe’…
[D][light:036]: ‘Raspiaudio Muse Luxe’ Setting:
[D][light:041]: Color mode: RGB
[C][adc.esp32:025]: Setting up ADC ‘Battery voltage’…
[C][i2s_audio:028]: Setting up I2S Audio…
[C][i2s_audio.microphone:018]: Setting up I2S Audio Microphone…
[C][i2s_audio.speaker:096]: Setting up I2S Audio Speaker…
[I][speaker_media_player:121]: Set up speaker media player
[C][wifi:048]: Setting up WiFi…
[D][esp-idf:000]: I (2106) wifi:
[D][esp-idf:000]: wifi driver task: 3ffc8db4, prio:23, stack:6656, core=0
[D][esp-idf:000]:
[D][esp-idf:000][wifi]: I (2126) wifi:
[D][esp-idf:000][wifi]: wifi firmware version: bbd58fc31
[D][esp-idf:000][wifi]: I (2132) wifi:
[D][esp-idf:000][wifi]: wifi certification version: v7.0
[D][esp-idf:000][wifi]: I (2152) wifi:
[D][esp-idf:000][wifi]: config NVS flash: enabled
[D][esp-idf:000][wifi]: I (2163) wifi:
[D][esp-idf:000][wifi]: config nano formating: disabled
[D][esp-idf:000][wifi]: I (2183) wifi:
[D][esp-idf:000][wifi]: Init data frame dynamic rx buffer num: 512
[D][esp-idf:000][wifi]: I (2204) wifi:
[D][esp-idf:000][wifi]: Init static rx mgmt buffer num: 5
[D][esp-idf:000][wifi]: I (2214) wifi:
[D][esp-idf:000][wifi]: Init management short buffer num: 32
[D][esp-idf:000][wifi]: I (2235) wifi:
[D][esp-idf:000][wifi]: Init static tx buffer num: 8
[D][esp-idf:000][wifi]: I (2256) wifi:
[D][esp-idf:000][wifi]: Init tx cache buffer num: 32
[D][esp-idf:000][wifi]: I (2276) wifi:
[D][esp-idf:000][wifi]: Init static rx buffer size: 1600
[D][esp-idf:000][wifi]: I (2286) wifi:
[D][esp-idf:000][wifi]: Init static rx buffer num: 16
[D][esp-idf:000][wifi]: I (2306) wifi:
[D][esp-idf:000][wifi]: Init dynamic rx buffer num: 512
[D][esp-idf:000]: I (2318) wifi_init: rx ba win: 32
[D][esp-idf:000]: I (2327) wifi_init: tcpip mbox: 512
[D][esp-idf:000]: I (2327) wifi_init: udp mbox: 6
[D][esp-idf:000]: I (2337) wifi_init: tcp mbox: 512
[D][esp-idf:000]: I (2347) wifi_init: tcp tx win: 65535
[D][esp-idf:000]: I (2357) wifi_init: tcp rx win: 65535
[D][esp-idf:000]: I (2357) wifi_init: tcp mss: 1436
[D][esp-idf:000]: I (2368) wifi_init: WiFi/LWIP prefer SPIRAM
[D][esp-idf:000]: I (2378) wifi_init: WiFi IRAM OP enabled
[D][esp-idf:000]: I (2378) wifi_init: WiFi RX IRAM OP enabled
[C][wifi:061]: Starting WiFi…
[C][wifi:062]: Local MAC: 40:22:D8:02:1E:B8
[D][esp-idf:000][wifi]: I (2400) phy_init: phy_version 4840,02e0d70,Sep 2 2024,19:39:07
[D][esp-idf:000][wifi]: I (2482) wifi:
[D][esp-idf:000][wifi]: mode : softAP (40:22:d8:02:1e:b9)
[D][esp-idf:000][wifi]: I (2484) wifi:
[D][esp-idf:000][wifi]: Total power save buffer number: 4
[D][esp-idf:000][wifi]: I (2487) wifi:
[D][esp-idf:000][wifi]: Init max length of beacon: 752/752
[D][esp-idf:000][wifi]: I (2508) wifi:
[C][wifi:263]: Setting up AP…
[C][wifi:265]: AP SSID: ‘Raspiaudio-luxe’
[C][wifi:266]: AP Password: ‘12345678’
[D][esp-idf:000][wifi]: I (2778) wifi:
[C][wifi:275]: IP Address: 192.168.4.1
[D][esp-idf:000][wifi]: I (2783) wifi:
[D][esp-idf:000][wifi]: mode : sta (40:22:d8:02:1e:b8) + softAP (40:22:d8:02:1e:b9)
[D][esp-idf:000][wifi]: I (2794) wifi:
[D][esp-idf:000][wifi]: enable tsf
[D][wifi:482]: Starting scan…
[C][api:026]: Setting up Home Assistant API server…
[C][micro_wake_word:062]: Setting up microWakeWord…
[C][micro_wake_word:069]: Micro Wake Word initialized
[D][main:818]: ==>>>update_led
[D][light:047]: State: ON
[D][light:058]: Red: 100%, Green: 0%, Blue: 100%
[D][light:109]: Effect: ‘slow_pulse’
[I][app:062]: setup() finished successfully!
[D][esp32.preferences:142]: Saving 1 preferences to flash: 1 cached, 0 written, 0 failed
[D][sensor:093]: ‘Battery voltage’: Sending state 4.56676 V with 2 decimals of accuracy
[D][esp-idf:000][wifi]: I (2888) wifi:
[D][esp-idf:000][wifi]: Set ps type: 0, coexist: 0
[W][component:157]: Component api set Warning flag: unspecified
[I][app:100]: ESPHome version 2025.2.2 compiled on Mar 17 2025, 12:26:56
[C][logger:177]: Logger:
[C][logger:178]: Max Level: DEBUG
[C][logger:179]: Initial Level: DEBUG
[C][logger:181]: Log Baud Rate: 115200
[C][logger:182]: Hardware UART: UART0
[C][i2c.idf:079]: I2C Bus:
[C][i2c.idf:080]: SDA Pin: GPIO18
[C][i2c.idf:081]: SCL Pin: GPIO23
[C][i2c.idf:082]: Frequency: 50000 Hz
[C][i2c.idf:088]: Recovery: bus successfully recovered
[I][i2c.idf:098]: Results from i2c bus scan:
[I][i2c.idf:104]: Found i2c device at address 0x10
[C][gpio.output:010]: GPIO Binary Output:
[C][gpio.output:011]: Pin: GPIO21
[C][template.sensor:022]: Template Sensor ‘Battery’
[C][template.sensor:022]: Device Class: ‘battery’
[C][template.sensor:022]: State Class: ‘measurement’
[C][template.sensor:022]: Unit of Measurement: ‘%’
[C][template.sensor:022]: Accuracy Decimals: 0
[C][template.sensor:023]: Update Interval: 15.0s
[C][esp32_rmt_led_strip:250]: ESP32 RMT LED Strip:
[C][esp32_rmt_led_strip:251]: Pin: 22
[C][esp32_rmt_led_strip:253]: RMT Symbols: 192
[C][esp32_rmt_led_strip:281]: RGB Order: GRB
[C][esp32_rmt_led_strip:282]: Max refresh rate: 0
[C][esp32_rmt_led_strip:283]: Number of LEDs: 1
[C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘Volume Up’
[C][gpio.binary_sensor:016]: Pin: GPIO19
[C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘Volume Down’
[C][gpio.binary_sensor:016]: Pin: GPIO32
[C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘Mute’
[C][gpio.binary_sensor:016]: Pin: GPIO12
[C][light:092]: Light ‘Raspiaudio Muse Luxe’
[C][light:094]: Default Transition Length: 0.0s
[C][light:095]: Gamma Correct: 2.80
[C][psram:020]: PSRAM:
[C][psram:021]: Available: YES
[C][psram:028]: Size: 4096 KB
[C][adc.esp32:058]: ADC Sensor ‘Battery voltage’
[C][adc.esp32:058]: Device Class: ‘voltage’
[C][adc.esp32:058]: State Class: ‘measurement’
[C][adc.esp32:058]: Unit of Measurement: ‘V’
[C][adc.esp32:058]: Accuracy Decimals: 2
[C][adc.esp32:059]: Pin: GPIO33
[C][adc.esp32:061]: Attenuation: auto
[C][adc.esp32:080]: Samples: 1
[C][adc.esp32:081]: Sampling mode: average
[C][adc.esp32:082]: Update Interval: 15.0s
[C][captive_portal:089]: Captive Portal:
[C][wifi:600]: WiFi:
[D][esp-idf:000][wifi]: W (3233) wifi:
[D][esp-idf:000][wifi]: Haven’t to connect to a suitable AP now!
[W][wifi_esp32:966]: esp_wifi_sta_get_ap_info failed: ESP_ERR_WIFI_NOT_CONNECT
[C][wifi:428]: Local MAC: 40:22:D8:02:1E:B8
[D][esp-idf:000][wifi]: W (3246) wifi:
[W][wifi_esp32:976]: esp_wifi_sta_get_ap_info failed: ESP_ERR_WIFI_NOT_CONNECT
[C][wifi:433]: SSID: ‘’[redacted]
[C][wifi:439]: BSSID: 00:00:00:00:00:00[redacted]
[C][wifi:441]: Hostname: ‘muse-luxe’
[D][esp-idf:000][wifi]: W (3277) wifi:
[W][wifi_esp32:987]: esp_wifi_sta_get_ap_info failed: ESP_ERR_WIFI_NOT_CONNECT
[C][wifi:443]: Signal strength: 0 dB ▂▄▆█
[C][wifi:447]: Channel: 3
[C][wifi:448]: Subnet: 0.0.0.0
[C][wifi:449]: Gateway: 0.0.0.0
[C][wifi:450]: DNS1: 0.0.0.0
[C][wifi:451]: DNS2: 0.0.0.0
[C][mdns:116]: mDNS:
[C][mdns:117]: Hostname: muse-luxe
[C][esphome.ota:073]: Over-The-Air updates:
[C][esphome.ota:074]: Address: muse-luxe.local:3232
[C][esphome.ota:075]: Version: 2
[C][safe_mode:018]: Safe Mode:
[C][safe_mode:019]: Boot considered successful after 60 seconds
[C][safe_mode:021]: Invoke after 10 boot attempts
[C][safe_mode:022]: Remain in safe mode for 300 seconds
[C][api:140]: API Server:
[C][api:141]: Address: muse-luxe.local:6053
[C][api:145]: Using noise encryption: NO
[C][micro_wake_word:051]: microWakeWord:
[C][micro_wake_word:052]: models:
[C][micro_wake_word:015]: - Wake Word: Okay Nabu
[C][micro_wake_word:016]: Probability cutoff: 0.850
[C][micro_wake_word:017]: Sliding window size: 5
[D][light:051]: Brightness: 100%
[D][light:058]: Red: 0%, Green: 0%, Blue: 100%
[D][light:109]: Effect: ‘pulse’
[D][ring_buffer:034]: Created ring buffer with size 2048
[D][micro_wake_word:399]: Resetting buffers and probabilities
[D][micro_wake_word:194]: State changed from IDLE to START_MICROPHONE
[W][component:237]: Component script took a long time for an operation (76 ms).
[W][component:238]: Components should block for at most 30 ms.
[D][micro_wake_word:107]: Starting Microphone
[D][micro_wake_word:194]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[D][micro_wake_word:194]: State changed from STARTING_MICROPHONE to DETECTING_WAKE_WORD
[D][sensor:093]: ‘Battery voltage’: Sending state 4.56333 V with 2 decimals of accuracy
entry 0x4008064c
Two methods
1 - with your PC
2 - with your smartphone
  • WiFI ==> ssid: “Raspiaudio-luxe” password: “12345678”
  • Chrome ==> 192.168.4.1
  • follow instructions…
Method 1
After successful installation
Method 2
Method 2:
try to disconnect your 4G
Thanks a lot, that worked. :slightly_smiling_face:
I am glad that my Muse Luxe is no longer a stumbling block after weeks. :heart_eyes:
Where do we get this file and how do we install it? Im having the same issue
Still getting the error: ```
Device gets stuck in a boot loop.
Please, give me more details !
How did you load your Luxe?
  • By compiling luxe_microWW.yaml with esphome ?
  • By loading from raspiaudio.github.io ?
  • By loading luxe_microWW.bin using esptool.py ?
LR
Through http://raspiaudio.github.io/ Every time I’ve ever tried to compile with esphome, there are so many errors, that I give up. Will an updated version be published at http://raspiaudio.github.io/ anytime soon?
Hi rgnet5 !
His site gives the latest version which works well…
I will try to help you step by step…
Question #1 : Have you initialized your WiFi credentials?
LR
(Send me as many details as possible…)
As of yesterday, the version at raspiaudio.github.io causes the Muse Luxe to fail during boot, with the error “Virtual address not enough for PSRAM, map as much as we can. 4MB is mapped”. The boot process loops indefinitely and the AP never loads, so WiFi credentials cannot be set. As documented here: Installing Home Assistant on Muse Luxe not possible · Issue #5 · RASPIAUDIO/esphomeLuxe · GitHub. So unless the version on the website has been updated in the past 24 hours, it will not work. I am however able to load an older version from this site: Ready-Made Projects — ESPHome which does work, but has a separate issue of repeating TTS messages in Home Assistant as documented here after upgrading from 2025.3.4 to 2025.4.0 esphome tts keeps repeating · Issue #142216 · home-assistant/core · GitHub
Hi!
" Virtual address not enough for PSRAM…" is just a warning and does not stop the loading process…
Probably your Luxe is looping waiting for WiFi connection…
Can vous send me a copy of your screen ?
Thx
Lr
Thank you, but that is not what is happening. It never gets to the point where it scans the Wi-Fi networks or starts up the internal access point. I do know how to connect to Wi-Fi and enter the credentials for this device. It loops over and over again and eventually the web installer hangs up and freezes, and I have to close out and start again. I have tried this installation from two different systems with the same end result. I have successfully been using the speaker for quite a while with older versions of the ESP Home Luxe firmware. When I saw there was a new version available I tried to update and it failed. I have reverted back to an older version, and it is working to some extent, but experiencing the repeating TTS messages, which seems to be a problem in this version of ESP Home and not the Muse Luxe itself.
Please, send me your logs so I can help you!..
LR
