Hello Raspiaudio! I am trying to setup a voice assistant with my Rpi4 and your Ultra ++ for Home assistant.
I was able to install the drivers from
and test aplay/arecord successfully with wav files.
I had a problem after installing Wyoming and openwakeword, but after several system updates now everything is running.
Then I noticed that the soundcard service has failed to start:
hass@assistant:~ $ sudo systemctl status wyoming-openwakeword.service wm8960-soundcard.service wyoming-satellite.service
● wyoming-openwakeword.service - Wyoming openWakeWord
Loaded: loaded (/etc/systemd/system/wyoming-openwakeword.service; disabled; preset: enabled)
Active: active (running) since Fri 2024-10-18 22:33:38 CEST; 5s ago
Main PID: 1890 (python3)
Tasks: 7 (limit: 3909)
CPU: 1.049s
CGroup: /system.slice/wyoming-openwakeword.service
├─1890 python3 /home/hass/wyoming-openwakeword/script/run --uri tcp://127.0.0.1:10701
└─1901 /home/hass/wyoming-openwakeword/.venv/bin/python3 -m wyoming_openwakeword --uri tcp://127.0.0.1:10701
Oct 18 22:33:38 assistant systemd[1]: Started wyoming-openwakeword.service - Wyoming openWakeWord.
Oct 18 22:33:40 assistant run[1901]: INFO:root:Ready
× wm8960-soundcard.service - WM8960 soundcard service
Loaded: loaded (/etc/systemd/system/wm8960-soundcard.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Fri 2024-10-18 22:33:40 CEST; 3s ago
Process: 1891 ExecStart=/usr/bin/wm8960-soundcard (code=exited, status=99)
Main PID: 1891 (code=exited, status=99)
CPU: 242ms
Oct 18 22:33:38 assistant systemd[1]: Starting wm8960-soundcard.service - WM8960 soundcard service...
Oct 18 22:33:38 assistant wm8960-soundcard[1891]: + exec
Oct 18 22:33:38 assistant wm8960-soundcard[1892]: ++ basename /usr/bin/wm8960-soundcard
Oct 18 22:33:40 assistant systemd[1]: wm8960-soundcard.service: Main process exited, code=exited, status=99/n/a
Oct 18 22:33:40 assistant systemd[1]: wm8960-soundcard.service: Failed with result 'exit-code'.
Oct 18 22:33:40 assistant systemd[1]: Failed to start wm8960-soundcard.service - WM8960 soundcard service.
● wyoming-satellite.service - Wyoming Satellite
Loaded: loaded (/etc/systemd/system/wyoming-satellite.service; disabled; preset: enabled)
Main PID: 1895 (python3)
Tasks: 4 (limit: 3909)
CPU: 812ms
CGroup: /system.slice/wyoming-satellite.service
├─1895 python3 /home/hass/wyoming-satellite/script/run --name assistant --uri tcp://0.0.0.0:10700 --mic-command "arecord -D plughw:CARD=wm8960>
├─1905 /home/hass/wyoming-satellite/.venv/bin/python3 -m wyoming_satellite --name assistant --uri tcp://0.0.0.0:10700 --mic-command "arecord ->
└─1922 arecord -D plughw:CARD=wm8960soundcard,DEV=0 -q -r 16000 -c 1 -f S16_LE -t raw
Oct 18 22:33:39 assistant run[1905]: INFO:root:Ready
Oct 18 22:33:39 assistant run[1905]: DEBUG:root:Detected IP: 192.168.1.1
Oct 18 22:33:39 assistant run[1905]: DEBUG:root:Zeroconf discovery enabled (name=dca6328950b2, host=None)
Oct 18 22:33:39 assistant run[1905]: DEBUG:root:Connecting to mic service: ['arecord', '-D', 'plughw:CARD=wm8960soundcard,DEV=0', '-q', '-r', '16000', '-c'>
Oct 18 22:33:39 assistant run[1905]: DEBUG:root:Connecting to snd service: ['aplay', '-D', 'plughw:CARD=wm8960soundcard,DEV=0', '-q', '-r', '22050', '-c', >
Oct 18 22:33:39 assistant run[1905]: DEBUG:root:Connecting to wake service: tcp://127.0.0.1:10400
Oct 18 22:33:39 assistant run[1905]: INFO:root:Connected to services
Oct 18 22:33:39 assistant run[1905]: DEBUG:root:Using webrtc audio enhancements
Oct 18 22:33:39 assistant run[1905]: DEBUG:root:Connected to mic service
Oct 18 22:33:39 assistant run[1905]: DEBUG:root:Connected to wake service
after that I realised my Rpi can recognize the wake word once , then I have to restart all 3 services. Can someone help me to understand what’s going on?
