How to fix " BALENA_HOST_CONFIG_dtoverlay " in Balena Sound software for Rpi in order to listen/activate audio by the Raspiaudio Audio+ DAC ?
Thank you for consider this support request
Hi I wanted to try Balena, I will do it this week and post here.
Well it works straight of the box with the AUDIO+ and MIC+ I jest followed the guide here:
- Click on the specific device within the application and select
Device configuration
in the left-side menu.- Add an additional custom configuration variable called
. The value of this will depend on your DAC board (see table below).
hifiberry-dac
also change this:
