Hey Guys.
First of all thanks for providing such nice HAT.
Im currently working my setup but there is some stuff driving me nuts making no sense to me at all.
My goal is to config the ULTRA++ as a Mic-In && Headphone-Out only device.
Onboard-Mic and -Speakers must not work.
- When i load
preset_external_jack_microphone_input2noffplayor any other functionality seems to work (very strange) - When i load
preset_onboard_Speakers_and_headphone_jack_outputinstead playback works just fine from both expected outputs (pluged headphones && onboard speakers) - So I put down the onboard speakers manually by
alsamixerand stored it as my custom preset - To enable the desired mic/recording feature I first compared the broken
preset_external_jack_microphone_input2vspreset_onboard_Speakers_and_headphone_jack_outputby faders atalsamixerand finally managed to set up some kind of recording by adjusting my custom preset with working output to also have the desired input. - But: It seems like its only recording from Input1 (onboard) even if Input2 (mic-in) is the only source been tuned up in
alsamixer. I tried several alternatives to isolate the problem but could not to manage to get any recording from the mic-in.
Please help me out. Thats alot for reviewing my current custom preset:
state.wm8960soundcard {
control.1 {
iface MIXER
name ‘Capture Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 63’
dbmin -1725
dbmax 3000
dbvalue.0 2550
dbvalue.1 2550
control.2 {
iface MIXER
name ‘Capture Volume ZC Switch’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 1’
control.3 {
iface MIXER
name ‘Capture Switch’
value.0 true
value.1 true
comment {
access ‘read write’
type BOOLEAN
count 2
control.4 {
iface MIXER
name ‘Left Input Boost Mixer LINPUT3 Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
dbmin -9999999
dbmax 600
dbvalue.0 -9999999
control.5 {
iface MIXER
name ‘Left Input Boost Mixer LINPUT2 Volume’
value 5
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
dbmin -9999999
dbmax 600
dbvalue.0 0
control.6 {
iface MIXER
name ‘Right Input Boost Mixer RINPUT3 Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
dbmin -9999999
dbmax 600
dbvalue.0 -9999999
control.7 {
iface MIXER
name ‘Right Input Boost Mixer RINPUT2 Volume’
value 5
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
dbmin -9999999
dbmax 600
dbvalue.0 0
control.8 {
iface MIXER
name ‘Right Input Boost Mixer RINPUT1 Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 3’
dbmin 0
dbmax 2900
dbvalue.0 0
control.9 {
iface MIXER
name ‘Left Input Boost Mixer LINPUT1 Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 3’
dbmin 0
dbmax 2900
dbvalue.0 0
control.10 {
iface MIXER
name ‘Playback Volume’
value.0 247
value.1 247
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 255’
dbmin -9999999
dbmax 0
dbvalue.0 -400
dbvalue.1 -400
control.11 {
iface MIXER
name ‘Headphone Playback Volume’
value.0 123
value.1 123
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 127’
dbmin -9999999
dbmax 600
dbvalue.0 200
dbvalue.1 200
control.12 {
iface MIXER
name ‘Headphone Playback ZC Switch’
value.0 false
value.1 false
comment {
access ‘read write’
type BOOLEAN
count 2
control.13 {
iface MIXER
name ‘Speaker Playback Volume’
value.0 7
value.1 7
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 127’
dbmin -9999999
dbmax 600
dbvalue.0 -11400
dbvalue.1 -11400
control.14 {
iface MIXER
name ‘Speaker Playback ZC Switch’
value.0 false
value.1 false
comment {
access ‘read write’
type BOOLEAN
count 2
control.15 {
iface MIXER
name ‘Speaker DC Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 5’
control.16 {
iface MIXER
name ‘Speaker AC Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 5’
control.17 {
iface MIXER
name ‘PCM Playback -6dB Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.18 {
iface MIXER
name ‘ADC Polarity’
value ‘No Inversion’
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 ‘No Inversion’
item.1 ‘Left Inverted’
item.2 ‘Right Inverted’
item.3 ‘Stereo Inversion’
control.19 {
iface MIXER
name ‘ADC High Pass Filter Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.20 {
iface MIXER
name ‘DAC Polarity’
comment {
access ‘read write’
type ENUMERATED
count 1
control.21 {
iface MIXER
name ‘DAC Deemphasis Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.22 {
iface MIXER
name ‘3D Filter Upper Cut-Off’
value Low
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 High
item.1 Low
control.23 {
iface MIXER
name ‘3D Filter Lower Cut-Off’
value Low
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 Low
item.1 High
control.24 {
iface MIXER
name ‘3D Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 15’
control.25 {
iface MIXER
name ‘3D Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.26 {
iface MIXER
name ‘ALC Function’
value Off
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 Off
item.1 Right
item.2 Left
item.3 Stereo
control.27 {
iface MIXER
name ‘ALC Max Gain’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
control.28 {
iface MIXER
name ‘ALC Target’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 15’
control.29 {
iface MIXER
name ‘ALC Min Gain’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
control.30 {
iface MIXER
name ‘ALC Hold Time’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 15’
control.31 {
iface MIXER
name ‘ALC Mode’
value ALC
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 ALC
item.1 Limiter
control.32 {
iface MIXER
name ‘ALC Decay’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 15’
control.33 {
iface MIXER
name ‘ALC Attack’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 15’
control.34 {
iface MIXER
name ‘Noise Gate Threshold’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 31’
control.35 {
iface MIXER
name ‘Noise Gate Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.36 {
iface MIXER
name ‘ADC PCM Capture Volume’
value.0 246
value.1 246
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 255’
dbmin -9999999
dbmax 3000
dbvalue.0 2550
dbvalue.1 2550
control.37 {
iface MIXER
name ‘Left Output Mixer Boost Bypass Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
dbmin -2100
dbmax 0
dbvalue.0 -2100
control.38 {
iface MIXER
name ‘Left Output Mixer LINPUT3 Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
dbmin -2100
dbmax 0
dbvalue.0 -2100
control.39 {
iface MIXER
name ‘Right Output Mixer Boost Bypass Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
dbmin -2100
dbmax 0
dbvalue.0 -2100
control.40 {
iface MIXER
name ‘Right Output Mixer RINPUT3 Volume’
value 0
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
dbmin -2100
dbmax 0
dbvalue.0 -2100
control.41 {
iface MIXER
name ‘ADC Data Output Select’
value ‘Left Data = Right ADC; Right Data = Right ADC’
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 ‘Left Data = Left ADC; Right Data = Right ADC’
item.1 ‘Left Data = Left ADC; Right Data = Left ADC’
item.2 ‘Left Data = Right ADC; Right Data = Right ADC’
item.3 ‘Left Data = Right ADC; Right Data = Left ADC’
control.42 {
iface MIXER
name ‘DAC Mono Mix’
value Stereo
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 Stereo
item.1 Mono
control.43 {
iface MIXER
name ‘Left Boost Mixer LINPUT2 Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.44 {
iface MIXER
name ‘Left Boost Mixer LINPUT3 Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.45 {
iface MIXER
name ‘Left Boost Mixer LINPUT1 Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.46 {
iface MIXER
name ‘Right Boost Mixer RINPUT2 Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.47 {
iface MIXER
name ‘Right Boost Mixer RINPUT3 Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.48 {
iface MIXER
name ‘Right Boost Mixer RINPUT1 Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.49 {
iface MIXER
name ‘Left Input Mixer Boost Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.50 {
iface MIXER
name ‘Right Input Mixer Boost Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.51 {
iface MIXER
name ‘Left Output Mixer PCM Playback Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.52 {
iface MIXER
name ‘Left Output Mixer LINPUT3 Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.53 {
iface MIXER
name ‘Left Output Mixer Boost Bypass Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.54 {
iface MIXER
name ‘Right Output Mixer PCM Playback Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.55 {
iface MIXER
name ‘Right Output Mixer RINPUT3 Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.56 {
iface MIXER
name ‘Right Output Mixer Boost Bypass Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.57 {
iface MIXER
name ‘Mono Output Mixer Left Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.58 {
iface MIXER
name ‘Mono Output Mixer Right Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
