I have the Pi Zero 2W and install the ULTRA ++ Audio HAT.
The instalation finished without problems.
I have a problem with the audio quuality. When i use the onboard mic to take a record file the quality is ok.
If i use the “Line In” jack with some music and play it over the “headphone jack” you only hear some bits. It seems like a oversteer audio signal.
I need to use the Mic jack oder Line in Jack to put in audio files like Music.
- I am nott sure if the installation / config is correct because if i start “pavucontrol” i can switch between headphone and speakers in the output menu. In the input menu i only see the onboard mic not the Mic jack. i cant choose the Mic Jack as input.
Can somebody help me ?
