I’ve been using a few Logitech Squeezebox Radios and also use them as alarm clocks. Since the devices are getting quite old, I’m considering replacing them with Muse Radio. I have a few questions about their functionality. Can I do the following with Muse Radio?
Use it as an alarm clock?
Set an alarm time locally and centrally via Lyrion Music Server or the Squeeze smartphone app?
Stream music to wake up from the LMS?
Bridge a power outage with the built-in battery and wake up with a fallback to local sounds or MP3 music on the SD card?
For the first 3 queries I expect the answer is yes - since this is LMS functionality and independent of the player.
However, not so confident about the last one since this would rely on functionality in Squeezelite ESP32 … and that might have been removed in the port to ESP-32 to save space.
Hi, to my knowledge, SD cards are not supported in Squeezelite-ESP32. However, I don’t see any issue with playing a local file from your LMS. Just keep in mind that if you want to be able to play music off-grid, you’ll probably need both your router and your LMS server to be connected to a UPS.
The Radio is a good device, but i’m not very objective as I’ve made it
Hello Raspiaudio,
Thanks for the reply.
The LMS server and router are UPS-backed, but not the Wi-Fi access points; they’re spread out and too far away.
Too bad, the old Squeece Radios simply played a built-in sound in this case. Otherwise, the Muse Radio would meet all my requirements.
I’ll take another look to see if Squeecelite has a solution for this.
The ESP-32 devices behave similar to SB Boom rather than a SB Radio.
SB Boom had fall back alarm capability but it was simple tone and I’m nto sure how it works. To mimic Boom alarm fallback, it would need development work on Squeeze-ESP-32 and since most ESP-32 device do not have an SD card - the generic solution would have a fixed alarm sound in memory and that also depends on what space is available.
I bought a Muse Radio recently. I want to change a button function for snooze/sleep like Boom’s top button but at present don’t have development time - hopefully in a few months.
