I’m using a Raspberry Zero W and the Audio+ hat. Everything works fine, but unfortunately the snapcast client seems not to work with it. It seems that it can not connect to the audio+ device.
I tried also using volumio (works well), but again the snapclient does not seem to recognize the device.
I used the following instructions:
AUDIO+ installation guide => works!
https://gist.github.com/gotling/9310f2572e1ea9c9d685c4ce5807001a => does not work.
The output from the snapclient service see below (192.168.123.18 is the snapcast server).
Do you have any idea how to solve this?
Thanks in advance
Desh
● snapclient.service - Snapcast client
Loaded: loaded (/lib/systemd/system/snapclient.service; enabled; vendor preset: enabled
Active: active (running) since Sat 2020-10-10 21:00:49 CEST; 20s ago
Process: 817 ExecStart=/usr/bin/snapclient -d -s 1 $USER_OPTS $SNAPCLIENT_OPTS (code=exi
Main PID: 818 (snapclient)
CGroup: /system.slice/snapclient.service
└─818 /usr/bin/snapclient -d -s 1 --user snapclient:audio --host 192.168.123.18
Okt 10 21:00:49 snapclient1 systemd[1]: Starting Snapcast client…
Okt 10 21:00:49 snapclient1 snapclient[818]: daemon started
Okt 10 21:00:49 snapclient1 systemd[1]: Started Snapcast client.
Okt 10 21:00:49 snapclient1 snapclient[818]: Connected to 192.168.123.18
