We can now test your RASPIAUDIO DAC+ and SPEAKER+ models
Set your speakers at a low volume!
Do you wish to test your system now? [y/N] y
Testing...
speaker-test 1.2.8
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Playback open error: -524,Unknown error 524
All done!
music@raspberrypi:~ $ sudo speaker-test
speaker-test 1.2.8
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
This is a pi zero w running pi os lite, bookworm.
I about 3 weeks prior got the board ], soldered the pin connector in, connected the board, loaded the SD Card, run the audio script for setting up the audio+ v2. All worked will… I messed up the setup trying setup an ad-hoc network. So today I pulled the SD card and loaded it fresh again but this time when I ran the audio+ V2 install script and I am receiveing the above.
I am about to run through a full setup again just to make sure…
music@music:~ $ sudo wget -O - script.raspiaudio.com | bash
Redirecting output to ‘wget-log’.
This script will install everything needed to use
Do you wish to continue? [y/N] yes
Checking hardware requirements...
Adding Device Tree Entry to /boot/config.txt
dtoverlay=hifiberry-dac
Default sound driver currently not loaded
Configuring sound output
Testing...
speaker-test 1.2.8
WAV file(s)
All done!
Enjoy your new RASPIAUDIO DAC+ and SPEAKER+ models!
Some changes made to your system require
your computer to reboot to take effect.
Would you like to reboot now? [y/N] y
Broadcast message from root@music on pts/1 (Sat 2024-02-17 13:19:08 CST):
The system will reboot now!
music@music:~ $ Connection to 192.168.138.87 closed by remote host.
Connection to 192.168.138.87 closed.
raksasas@T560:~$ ssh music@192.168.138.87
music@192.168.138.87's password:
Linux music 6.1.0-rpi8-rpi-v6 #1 Raspbian 1:6.1.73-1+rpt1 (2024-01-25) armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Feb 17 11:57:48 2024 from 192.168.138.38
music@music:~ $ speaker-test -l5 -c2 -t wav
speaker-test 1.2.8
WAV file(s)
music@music:~ $ sudo speaker-test -l5 -c2 -t wav
speaker-test 1.2.8
WAV file(s)
music@music:~ $
I have tried again this morning and it is working check that you did the same starting with a new SD card to try:
-Took a fresh SD card and burnt RPI OS 64bit Bookworm Released 2023-12-05
-Inserted it in my RPI5 with on top the MIC+ hat
-Opened a terminal and typed :
-When prompted to, I rebooted
-Back on the desktop right click on the speaker on the top right corner to select the device “snd_rpi…”
-Opened a youtube video and can hear the music
Well, first off, I am not able to use the “Raspberry Pi Imager” … Which I think is junk… I don’t run Windows, nor Ubuntu/Debian. So that isn’t an option. I am using the “dd” command
doing what you said in “/boot/firmware/config.txt” I have audio now… when i run the
speaker-test 1.2.8
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 8 to 131072
Period size range from 4 to 65536
Using max buffer size 131072
Periods = 4
was set period_size = 32768
was set buffer_size = 131072
0 - Front Left
1 - Front Right
Time per period = 0.733013
0 - Front Left
1 - Front Right
Time per period = 2.734532
0 - Front Left
1 - Front Right
Time per period = 3.404926
0 - Front Left
1 - Front Right
Time per period = 2.735595
0 - Front Left
1 - Front Right
Time per period = 4.085502
