Good morning
I have recently acquired a mic + 2v to install on a raspberry pi 4 b, and use it for Rhasspy on home assistant for volcale recognition.
Once installed, the status LED does not light up and is not recognized by the system. also in the configuration phase when I use the command wget from the terminal it tells me that it cannot be executed don SUDO but only as root user, the command is
wget -O - mic.raspiaudio.com | bash
someone can tell me if I’m wrong or if the module is faulty
thank you
