please send it back thru Amazon, if you have passed your return date PM me and send me your order number please.
I am having the same issue. Where is the reset button?
-turn off your Luxe.
-insert a paper clip in the jack port on th back until you feel a button click, maintain it pressed.
-Turn on your luxe
-you can release the button and you should be in downloads mode, try to flash again.
If this does not work try to press the button while trying to update when the wheel is turning on th web interface.
Fantastic. I had also left it on over night as to drain the battery. Between that and your instructions I was able to re-flash the firmware. Thanks!
Hi there, I’m having similar issues with my Muse Luxe. Managed to flash it a few times with different pre-loaded projects but now it’s dead. Heading over to apps.raspiaudio.com, connecting and viewing the logs returns nothing, even while toggling the device on and off. Performing a software “reset” does nothing.
Where exactly is the hard reset pinhole? I have a 3.5mm AUX port so I’m guessing that’s not it. I have a pinhole beside the USB-C port but that appears to be just an LED for cable connection feedback. There are two pinholes on the top of the speaker but I’m pretty sure they’re Mic and RGB LED
Please help! Thank you.
Hidden inside the back of the aux socket
Thanks, found it and tried numerous resets. All I can manage to get out of the logs is a single line:
Terminal disconnected: BreakError: Break received
Hello
Usually this is just a software crash preventing the auto reset.
Try to maintaining the hidden jack button while wheel is spinning on apps.raspiaudio.com
Let me know, otherwise send me a private message here with your order number.
Thanks for the reply. Appreciated.
I’ve tried holding down the hidden reset pin while the blue circle connects to the device but this hasn’t worked either. I’ve also tried holding down the reset button while clicking “reset device” from within the console window but that doesn’t work. I’ll PM you with my details.
Hi @Raspiaudio,
With squeezelite and music assistant I cannot get TTS to work.
What am I missing? Or will this just not work, ever?
Thanks,
iGor
My understanding is that there is a software limitation in HA, I will try to understand why as on a purely hardware side it is possible to record and play simultaneously on the I2S interface. Maybe it worth to open a ticket or ask on a dedicated HA forum.
Not sure why and how, TTS works, but for some reason it shortens the announcements.
Always by a few seconds.
I’ve tried with shorter and longer text, tried by adding a time delay in the automation, even executed directy from a script but still gets shortened.
I assume the voice is a generated file placed somewhere and played, not sure if I should start looking in this direction…
Any help is appreciated.
I’ve made a short tutorial for newcomers ![]()
This is a tutorial to enable the ESP MUSE LUXE hackable speaker to stream audio using :
Airplay, Spotify, Bluetooth, and local files using LMS, all thanks to the open source project Squeezelite ESP32.
I have received my MUSE LUXE and plug it to my LMS.
And I have updated to last available firmware in list.
But I have issue with sound quality when I play my files encoded as FLAC files (sampling rate : 44.1 kHz and size: 16 bits)… I have already tested them on various squeeze player without any issue.
I will test more. Any idea of what I can do to solve this?
Hi, It’s only happening with flac files?
It is not clear… there are my firsts tests… I will not be able to do more tests during one week.
Now I am listening a Flac that seems good…
with some it is horrible from the beginning, for others it start after few minutes…
I do not know which file property I should check… for example, current file is 470Kbps VBR. it seems OK. One that is in problem at first note is 944. And now I have trouble with one having 834…
To note, I have some timeouts in the status log
| Timestamp | Message |
| 21/03/2025 21:31 | timeout |
also it is systematic. I mean a track with issue, there are issues each time I am playing it.
Hello, after a week off, I am back… And can say that I cannot reproduce the issue of first day. Even with same flac files.
no problem, let me know if it happens again.
thank you, it happens again… I believe it is related to wifi / network throughput…
I am sitting at 4 meters from my wifi (freebox v4) and when I put the Muse device 80 cm from me on my left side(closer to freebox), sounds is OK. When I put it on right side sounds is dirty…
When I do same test with a song having a low VBR, I cannot notice any default in sound.
This experience (right side. left side with a 900 Kbps VBR file), I can repeat it 10 times with the same song: sound will be OK on left side and KO on right side.
I don’t remember where I was, when I notice the issue the first time.
are there known issues with the wifi card?
