I would like to use the 8In/8Out board with a Raspberry Pi 5… . ….
Does anyone here have experience with using this hardware with Max/MSP and/or the Processing Language?
Thank you,
TomC
Thank you,
TomC
What DAW/Audio SW are people using? Audacity? Reaper?
Thank you,
Hi Tom,
Once the driver is installed, the 8In/8Out board is available as a Linux audio device. Software compatibility depends on whether the application runs on the Pi and supports multichannel audio. Most of them does but check it.
Remember this board is only for PI5
For the applications you mentioned:
Start with our installation guide to verify the hardware before configuring your application.
Thank you for your thoughtful reply.
I neglected to notice that Max/MSP is not available on the RPi.
However, pd is available on the RPi; I will try that.
Regards,
TomC
