ULTRA++ installation guide
I’ve followed the guide as-is in the top post
At this step:speaker-test -l5 -c2 -t wav
i get
speaker-test 1.2.4
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Playback open error: -19,No such device
I have reinstalled per the next step
cd WM8960-Audio-HAT
sudo ./uninstall.sh
sudo ./install.sh
I am using a pi zero 2 w, with ultra++ hat, installed on Raspberry Pi OS Lite per rhasspy docs.
I note some conflicting advice in some of the comments about outdated drivers, and can see the top post was updated back in april. Do I need to be using a different driver? I want the headphones out and onboard microphones for this project.
Lastly: > `cd WM8960-Audio-HAT
sudo ./uninstall.sh
sudo ./install.sh`
in the guide should this not be cd ultra2? I don’t have a WM8960xxx directory that I could see.
