ULTRA++ installation guide
okay, did it from scratch - fresh raspbian image using raspberry pi imager.
I then proceeded to do this:
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
which then returned this:
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 6.12.55-v8+ #1915 SMP PREEMPT Fri Oct 24 11:49:06 BST 2025 aarch64 GNU/Linux
pi@raspberrypi:~ $ aplay -l
card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
  Subdevices: 8/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
card 1: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
  Subdevices: 1/1
card 2: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
  Subdevices: 1/1
Just to be clear, I have the old ULTRA++ card that does not feature the auto detect function.
Then have you tried the section of the installation guide" if the auto install does NOT work" :
OPTIONAL Manual installation PI5 / PI4 / ZERO (ONLY if the auto install does NOT work)
Once done you should be up to date
open a terminal and type:
and at the end of the file add:
dtoverlay=wm8960-soundcard.dtbo
Is this pinout accurate? If I plug the soundcard straight into the Pi, it works fine. But if I manually wire only the pins specified in the pinout, playback fails.
yes it should work, try to wire all grounds
On the Ultra ++ I want to input audio on the stereo external line input jack and
I want to send that audio to stereo headphones output jack. How can I accomplish this? Is it possible with alsamixer?
Yes you want to loopback the line input on the headphones, I think that the codec wm8960 has this option, then it will need to be convered by the current driver.
Check in alsamixer if you see a loopback control, otherwise we I’ll look at it next week.
I do not see a loopback control in Alsa mixer for either capture or playback. Let me know what you find.
probably the driver doesn’t expose these codec’s commands so alternative it to send directly these I2C commands to the codec, even this doc is for microcontroller you can use theire library to get the right commands to send to the Raspberry Pi
https://learn.sparkfun.com/tutorials/audio-codec-breakout---wm8960-hookup-guide/example-5-loopback?utm_source=chatgpt.com
Any AI thinking model will crush that in a minute
Hey raspiaudio,
I install ultra++ (orange) on my raspi4b following your up-to-date instruction.
Clean installation, bookworm 32bit, adding dtoverlay=wm8960-soundcard.dtbo
Everything went super well, the problem is I cannot get external microphone working. (on board microphone is working and sound well)
I also applied your extmic.alsa using alsctl restore but it seems to be not recording any sound.
You can check my alsamixer setup as screenshot below.
I am using TRS binaural microphone, which used to work before.
Are there some issues on the driver? Please let me know.
Thank you.
or could you please test if your current ‘extmic.alsa’ script functioning well from your side?
because onboard mic preset you uploaded works perfect…
yes we try to do it next week
just checked extmic.alsa and it is working here, so it is your microphone or ultra, but all board are tested before shipping.
I have a similar noise. Have you managed to fix it somehow?
Not sure the exact reason but when I use external battery, the noise was reduced.
My hat is an ultra++ orange model that I bought about a year ago, and the external mic used to work perfectly. After testing it back then, I stored it in a hard case for a year. When I tried using it again recently, it no longer worked.
I’ve tried many different methods, but still no success. Maybe the hat is broken somehow as you mentioned, and I might need to buy a new blue one.
Before I purchase the new blue ultra++, could you please confirm once more that extmic.alsa still works on the orange hat with your suggested installation method? It’s strange because it definitely worked a year ago, right before I stored it.
My microphone functions well with different recording devices, so it may not be the mic issue.
Thank you so much!
Raspiaudio
Seems confusing to me. How do I send I2C commands to the board? Want to use the Board for an amateur radio project. Any help would be appreciated.
Okay, I bought a new raspiaudio Ultra++ (blue model) and test my external microphone using your preset extmic.alsa
but it is not working.
Just to let you know: my microphone has no issue on other recording device (zoom H1n). I tested with three different 3.5mm external mics on Raspi Ultra and sound is not coming from the microphone.
I also think it’s not Ultra board issue because I just purchased a new one.
I have been struggling to make this work for a month and even bought a new model, so it would be really appreciated if you could help me on this.
Here is what I have done, please let me know if there’s something wrong in the process.
  1. Fresh install Raspi 5 Bookworm
  2. The driver (wm8960soundcard) has been automatically installed.
  3. create a file ‘extmic.alsa’ and paste the same code you provided: https://raw.githubusercontent.com/RASPIAUDIO/ULTRA/refs/heads/main/extmic.alsa
  4. alsactl --file extmic.alsa restore
  5. I checked alsamixer and new values are successfully restored
  6. arecord -D hw:2,0 -f dat -c 2 -d 5 test.wav
hjk@raspiaudio:~ $ arecord -l
**** List of CAPTURE Hardware Devices ****
card 2: wm8960soundcard [wm8960-soundcard], device 0: 1f000a0000.i2s-wm8960-hifi wm8960-hifi-0 [1f000a0000.i2s-wm8960-hifi wm8960-hifi-0]
Subdevices: 1/1
  1. aplay test.wav
    No sound from the file. I also moved the file to my laptop, open with DAW but no sound is recorded (only hum noise).
some other question: Is plugin power(PiP) needed?
Also ran into this same issue, everything but external mic input works.
RPI 5, latest Raspbian (trixie) version.
Card was recognized automatically but did not make any sound/input right away.
After wrestling with alsamixer config I got some sound, it seems to not be on by default anymore.
Now I got the internal mic working (though extremely noisy and kinda unusable, possibly due to my gpio).
Got line input working as well.
But the external mic gives no sound at all, no matter the gain.
Tried it using the extmic.alsa config. Looks OK in alsamixer but no sound at all. Tried 2 lav mics.
I’d imagine the board supplies plugin power on the mic input?
Hi, all boards microphone input are tested in our factory so I doubt of a hardware issue, nevertheless it’s not impossible that the driver has changed, we have one of our engineer scheduled next week to look at it. Please stay tunned here.
So I have a Raspberry PI 5 on Raspberry Pi OS. When I connect the Ultra ++ board, the OS recognises it but no audio. Tried all the methods (updating PI firmware, manual installation, custom driver).
The only one that seemed to work was custom driver - I could hear audio. But had this error and after restart, no more sound and OS doesn’t find the wm8960 anymore in audio bar (disappeared).
"Creating symlink /var/lib/dkms/wm8960-soundcard/1.0/source → /usr/src/wm8960-soundcard-1.0
Error! Your kernel headers for kernel 6.12.64-v8-16k+ cannot be found at /lib/modules/6.12.64-v8-16k+/build or /lib/modules/6.12.64-v8-16k+/source.
Please install the linux-headers-6.12.64-v8-16k+ package or use the --kernelsourcedir option to tell DKMS where it’s located.
Created symlink ‘/etc/systemd/system/sysinit.target.wants/wm8960-soundcard.service’ → ‘/usr/lib/systemd/system/wm8960-soundcard.service’.
Any advice? Tried everything but nothing working
