Muse Luxe with ESPHome voice assistant
Try again on raspiaudio.github.io…
It should work better…
Please, keep me posted
Best regards
Yes, now it looks like it’s working, but my encryption is gone and in Home Assistant I can’t transfer the pre-prepared yaml to the device with my settings because it keeps reinstalling.
As before, an expensive paperweight.
Without encryption and the ability to customize my settings, the thing is useless.
I used ESPHome and reconfigured with 2024.9.1 and brought it back from the dead. This is very fragile system, I’d use an alternative if there was a similarly priced alternative
Hi, we’ve recently completely redone all the YAML for the Radio, and it’s now stable and great to use. This week, we’ll focus on the Luxe — stay tuned, we’ll post the results here.
Hello, good news. We have a much more stable Home Assistant build for the Muse Luxe.
Features
  • Improved wake-word accuracy
  • Wake word selectable from the main panel
  • Reduced LED and audio update frequency to save resources
  • Switched to a WAV audio pipeline to save resources
  • Fixed loud crash issue
  • Audio jack output (Luxe V2 only)
Because this is a major update, you need to reflash your Luxe from our Open Source Apps Store.
Future updates will then appear via the Home Assistant Updater.
How to use :
  • flashing blue LED waiting for wakeword by default “Ok Nabu”
  • Green LED listening for commands, you can try “what time is it?”
  • Red led : playing media / not listening
middle buton :
  • push once : mute
  • pushed twice : go in wake word detetection mode
Source YAML is here.
Unfortunately still not completely fixed.
Still get a crash with huge loud noise here and there.
totally random crashes or when you do/play something specific? Got it in the office for days without crash.
It’s both. I am monitoring the uptime in Home Assistant and there are times when uptime counter just resets, i.e., device reboots (once a day maybe sometimes more frequent).
But more critical is when I play something specific. In this case I can reproduce this behavior fairly reliably. For example when I play something, after the 4th or 5th time it would crash (and I get a huge static as before).
This is the message on the console:
[11:13:52][D][main:197]: ====> hardware mute
[11:13:52][D][micro_wake_word:375]: State changed from STOPPED to STARTING
[11:13:52][D][micro_wake_word:258]: Inference task has started, attempting to allocate memory for buffers
[11:13:52][D][micro_wake_word:263]: Inference task is running
[11:13:52][D][micro_wake_word:375]: State changed from STARTING to DETECTING_WAKE_WORD
[11:13:52][D][ring_buffer:034][mww]: Created ring buffer with size 3840
[11:13:56][D][button:023]: 'SimpliChime' Pressed.
[11:13:56][D][micro_wake_word:367]: Stopping wake word detection
[11:13:56][D][speaker_media_player:406]: State changed to ANNOUNCING
[11:13:56][D][micro_wake_word:375]: State changed from DETECTING_WAKE_WORD to STOPPING
[11:13:56][D][speaker_media_player.pipeline:114]: Reading WAV file type
[11:13:56][D][ring_buffer:034][ann_read]: Created ring buffer with size 1000000
[11:13:56][D][micro_wake_word:270]: Inference task is stopping, deallocating buffers
[11:13:56][D][micro_wake_word:275]: Inference task is finished, freeing task resources
[11:13:56][D][micro_wake_word:375]: State changed from STOPPING to STOPPED
[11:13:56][D][main:690]: ==>>>update_led
[11:13:56][D][light:089]: 'Muse Luxe Diningrm' Setting:
[11:13:56][D][light:113]:   Red: 100%, Green: 50%, Blue: 0%
[11:13:56][D][light:163]:   Effect: 'None'
[11:13:56][D][speaker_media_player.pipeline:124]: Decoded audio has 1 channels, 16000 Hz sample rate, and 16 bits per sample
[11:13:56][D][i2s_audio.speaker:102]: Starting
[11:13:56][D][i2s_audio.speaker:106]: Started
[11:13:56][D][ring_buffer:034][speaker_task]: Created ring buffer with size 3200
[11:13:56][D][main:209]: ====> hardware unmute
[11:13:57][D][button:023]: 'SimpliChime' Pressed.
[11:13:57][D][speaker_media_player.pipeline:114]: Reading WAV file type
[11:13:57][D][ring_buffer:034][ann_read]: Created ring buffer with size 1000000
[11:13:57][D][speaker_media_player.pipeline:124]: Decoded audio has 1 channels, 16000 Hz sample rate, and 16 bits per sample
[11:13:58][D][button:023]: 'SimpliChime' Pressed.
[11:13:58][D][speaker_media_player.pipeline:114]: Reading WAV file type
[11:13:58][D][ring_buffer:034][ann_read]: Created ring buffer with size 1000000
[11:13:58][D][speaker_media_player.pipeline:124]: Decoded audio has 1 channels, 16000 Hz sample rate, and 16 bits per sample
[11:13:58]Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
[11:13:58]
[11:13:58]Core  0 register dump:
[11:13:58]PC      : 0x400996d9  PS      : 0x00060633  A0      : 0x80099190  A1      : 0x3ffd8990
[11:13:58]A2      : 0x3f804a20  A3      : 0x000000f6  A4      : 0xb33fffff  A5      : 0x00060023
[11:13:58]A6      : 0x0000001c  A7      : 0x3ffb6620  A8      : 0x000000f8  A9      : 0x00000003
[11:13:58]A10     : 0x0000001b  A11     : 0x3f800014  A12     : 0x00010655  A13     : 0x3f800038
[11:13:58]A14     : 0x3f800078  A15     : 0x00010655  SAR     : 0x0000001e  EXCCAUSE: 0x0000001d
[11:13:58]EXCVADDR: 0x00010661  LBEG    : 0x40090f78  LEND    : 0x40090f94  LCOUNT  : 0xffffffff
[11:13:58]
[11:13:58]
[11:13:58]Backtrace: 0x400996d6:0x3ffd8990 0x4009918d:0x3ffd89b0 0x400855db:0x3ffd89d0 0x400855fd:0x3ffd8a00 0x40085828:0x3ffd8a20 0x40085271:0x3ffd8a70 0x40212d3d:0x3ffd8a90 0x402163ad:0x3ffd8ac0 0x4021473e:0x3ffd8af0 0x40216b99:0x3ffd8b30 0x40216c7e:0x3ffd8b70 0x40210b4d:0x3ffd8bb0
[11:13:58]
[11:13:58]
[11:13:58]
[11:13:58]
[11:13:58]ELF file SHA256: 09a4e555a
[11:13:58]
[11:13:58]Rebooting...
(I was also discussing this in this older thread: Muse Luxe esphome loud buzzing sound - #32 by Raspiaudio)
For reference, this is my YAML.
Would you mind trying this one out and see if you can reproduce it?
api:
  encryption:
    key: "xxx"
wifi:
  ssid: !secret wifi_ssid
  power_save_mode: none
  output_power: 15
substitutions:
  friendly_name: "Muse Luxe Diningrm"
#States
  P_starting: "0"
  P_waiting: "1"
  P_playing: "2"
  P_listening: "3"
  P_answering: "4"
esphome:
  friendly_name: ${friendly_name}
  min_version: 2025.2.0
  name_add_mac_suffix: false
  platformio_options:
    board_build.flash_mode: dio
    board_build.arduino.memory_type: qio_opi
  project:
    version: "2025.3.0"
  on_boot:
    priority: -100.0
    then:
      - output.turn_on: dac_mute
      - lambda: id(muteH) = true;
      - lambda: id(phase) = 0;
      - script.execute: update_led
external_components:
    - source: github://RASPIAUDIO/esphomeLuxe@main
      components: [es8388]
      refresh: 0s
esp32:
  board: esp-wrover-kit
  flash_size: 4MB
  partitions: luxe_partitions2.csv
  framework:
    type: esp-idf
    version: recommended
    sdkconfig_options:
      CONFIG_ESP_CONSOLE_USB_CDC: "n"
      CONFIG_ESP_CONSOLE_UART_DEFAULT: "y"
      CONFIG_ESP_CONSOLE_UART_NUM: "0"
      CONFIG_ESP_CONSOLE_UART_BAUDRATE: "115200"
micro_wake_word:
  microphone: luxe_mic
  stop_after_detection: false
  models:
    - model: https://github.com/kahrendt/microWakeWord/releases/download/okay_nabu_20241226.3/okay_nabu.json
    - model: hey_jarvis
    - model: hey_mycroft
  on_wake_word_detected:
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
logger:
  level: DEBUG
  baud_rate: 115200
  hardware_uart: UART0
  logs:
    media_player: WARN
# Hardware Configuration
es8388:
psram:
  mode: quad
  speed: 80MHz
# Buses Configuration
i2c:
  sda: GPIO18
  scl: GPIO23
# Internal Components
output:
  - platform: gpio
    pin:
      number: GPIO21
      inverted: true
      mode:
        output: true
globals:
  - id: Vol
    type: float
    initial_value: '0.6'
  - id: phase
    type: int
    initial_value: '0'
  - id: mute
    type: bool
    initial_value: 'false'
  - id: muteH
    type: bool
  - id: last_led_phase
    type: int
    initial_value: '-1'
  - id: audio_active
    type: bool
  - id: audio_started
    type: bool
  - id: last_volume_cmd
    type: float
    initial_value: '-1.0'
interval:
  - interval: 0.1sec
    then:
      - if:
          condition:
             - speaker.is_stopped:
          then:
             - if:
                condition:
                  - not:
                     - lambda: 'return(id(muteH));'
                then:
                  - logger.log: "====> hardware mute"
      - if:
          condition:
             - speaker.is_playing:
          then:
             - if:
                condition:
                then:
                  - output.turn_off: dac_mute
                  - lambda: id(muteH) = false;
                  - logger.log: "====> hardware unmute"
      - if:
          condition:
            and:
              - lambda: 'return id(audio_active) && !id(audio_started);'
          then:
            - lambda: id(audio_started) = true;
sensor:
  - platform: uptime
  - platform: adc
    pin: GPIO33
    device_class: voltage
    unit_of_measurement: "V"
    accuracy_decimals: 2
    state_class: measurement
    entity_category: diagnostic
    update_interval: 15s
    attenuation: auto
    filters:
      - multiply: 2 # https://forum.raspiaudio.com/t/esp-muse-luxe-bluetooth-speaker/294/12
      - exponential_moving_average:
          alpha: 0.2
          send_every: 2
      - delta: 0.002
    on_value:
      then:
        - sensor.template.publish:
            state: !lambda "return x;"
  - platform: template
    device_class: battery
    unit_of_measurement: "%"
    accuracy_decimals: 0
    filters:
      - calibrate_polynomial:
          degree: 3
          datapoints:
            - 4.58 -> 100.0
            - 4.5 -> 97.1
            - 4.47 -> 94.2
            - 4.44 -> 88.4
            - 4.42 -> 82.7
            - 4.41 -> 76.9
            - 4.41 -> 71.1
            - 4.37 -> 65.3
            - 4.35 -> 59.5
            - 4.31 -> 53.8
            - 4.28 -> 48.0
            - 4.26 -> 42.2
            - 4.23 -> 36.4
            - 4.21 -> 30.6
            - 4.19 -> 24.9
            - 4.16 -> 19.1
            - 4.1 -> 13.3
            - 4.07 -> 10.4
            - 4.03 -> 7.5
            - 3.97 -> 4.6
            - 3.82 -> 1.7
            - 3.27 -> 0.0
      - lambda: return clamp(x, 0.0f, 100.0f);
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO27
      mode:
        input: true
        pullup: true
    internal: true
    on_press:
      - script.execute: jack_detect_high
    on_release:
      - script.execute: jack_detect_low
  - platform: gpio
    pin:
      number: GPIO19
      inverted: true
      mode:
        input: true
        pullup: true
    on_click:
        - lambda: |-
                id(Vol) += 0.05;
                if(id(Vol) > 1) id(Vol) = 1;
        - if:
            condition:
              lambda: 'return fabsf(id(last_volume_cmd) - id(Vol)) > 0.005f;'
            then:
              - media_player.volume_set:
                  volume: !lambda return id(Vol);
              - lambda: id(last_volume_cmd) = id(Vol);
  - platform: gpio
    pin:
      number: GPIO32
      inverted: true
      mode:
        input: true
        pullup: true
    on_click:
        - lambda: |-
                id(Vol) -= 0.05;
                if(id(Vol) < 0) id(Vol) = 0;
        - if:
            condition:
            then:
  - platform: gpio
    pin:
      number: GPIO12
      inverted: true
      mode:
        input: true
        pullup: true
    on_click:
      - script.execute: manual_listen
    on_double_click:
       - if:
           condition:
              - lambda: 'return(id(phase) == 2);'
           then:
              - media_player.stop:
light:
  - platform: esp32_rmt_led_strip
    pin: GPIO22
    chipset: WS2812
    num_leds: 1
    rgb_order: grb
#    rmt_channel: 0
    default_transition_length: 0s
    gamma_correct: 2.8
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
      - pulse:
          transition_length: 1s
          update_interval: 2s
i2s_audio:
    i2s_lrclk_pin: GPIO25
    i2s_bclk_pin: GPIO5
    i2s_mclk_pin: GPIO0
microphone:
  - platform: i2s_audio
    i2s_audio_id: i2s0
    sample_rate: 16000
    i2s_din_pin: GPIO35
    bits_per_sample: 16bit
    channel: stereo
    adc_type: external
speaker:
    i2s_audio_id: i2s0
    i2s_dout_pin: GPIO26
    dac_type: external
    sample_rate: 48000
    num_channels: 2
    buffer_duration: 100ms
media_player:
  - platform: speaker
    internal: false
#    task_stack_in_psram: true
#    volume_min: 0.5
#    volume_max: 0.8
    announcement_pipeline:
      speaker: luxe_speaker
      format: WAV
      sample_rate: 48000
      num_channels: 1
    files:
      - id: little_sound
        file: https://github.com/RASPIAUDIO/esphomeLuxe/raw/refs/heads/main/wav/sounds_timer_finished.wav
      - id: beep
        file: http://10.227.4.10:8123/local/beep.wav
      - id: SimpliChime
        file: http://10.227.4.10:8123/local/SimpliChime.wav
      - id: BurglarAlarm
        file: http://10.227.4.10:8123/local/Burglar-alarm-sound.mp3
    on_announcement:
      - micro_wake_word.stop:
      - wait_until:
          not:
            micro_wake_word.is_running:
      - microphone.mute: luxe_mic
      - lambda: |-
          id(audio_active) = true;
          id(audio_started) = false;
      - if:
           condition:
                lambda: 'return(id(phase) != 2);'
           then:
              - lambda: |-
                   if(id(phase) == 1)  id(phase) = 2;
              - script.execute: mute_off
    on_idle:
      - if:
          condition:
            lambda: 'return id(audio_active) && id(audio_started);'
          then:
            - wait_until:
               and:
                - not:
                    media_player.is_announcing:
                - not:
                    voice_assistant.is_running:
            - if:
                condition:
                    lambda: 'return((id(phase) == 4) || (id(phase) == 2));'
                then:
                  - lambda: |-
                       id(phase) = 1;
            - microphone.unmute: luxe_mic
            - micro_wake_word.start:
            - lambda: |-
                id(audio_active) = false;
    on_play:
      - if:
          condition:
            lambda: 'return !id(mute);'
          then:
select:
    name: "Wake word sensitivity"
    optimistic: true
    initial_option: Slightly sensitive
    restore_value: true
    entity_category: config
    options:
      - Slightly sensitive
      - Moderately sensitive
      - Very sensitive
    on_value:
      # Adjust model probability thresholds to tune wake word sensitivity
      lambda: |-
        if (x == "Slightly sensitive") {
          id(okay_nabu).set_probability_cutoff(217);    // 0.85 -> 0.000 FAPH on DipCo
          id(hey_jarvis).set_probability_cutoff(247);   // 0.97 -> 0.563 FAPH on DipCo
          id(hey_mycroft).set_probability_cutoff(253);  // 0.99 -> 0.567 FAPH on DipCo
        } else if (x == "Moderately sensitive") {
          id(okay_nabu).set_probability_cutoff(176);    // 0.69 -> 0.376 FAPH on DipCo
          id(hey_jarvis).set_probability_cutoff(235);   // 0.92 -> 0.939 FAPH on DipCo
          id(hey_mycroft).set_probability_cutoff(242);  // 0.95 -> 1.502 FAPH on DipCo
        } else if (x == "Very sensitive") {
          id(okay_nabu).set_probability_cutoff(143);    // 0.56 -> 0.751 FAPH on DipCo
          id(hey_jarvis).set_probability_cutoff(212);   // 0.83 -> 1.502 FAPH on DipCo
          id(hey_mycroft).set_probability_cutoff(237);  // 0.93 -> 1.878 FAPH on DipCo
voice_assistant:
  media_player: luxe_media_player
  micro_wake_word: mww
  use_wake_word: false
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  on_listening:
     - logger.log: "listening 3 => phase"
     - lambda: |-
        id(phase) = 3;
  on_stt_end:
     - light.turn_on:
        blue: 60%
        red: 20%
        green: 20%
        effect: pulse
  on_tts_start:
    - logger.log: "answering  4 => phase"
    - wait_until:
        not:
    - lambda: |-
    - lambda: |-
        id(phase) = 4;
  on_error:
    - logger.log: "ERROR!!!!!!!!!!!!!!!!"
    - light.turn_on:
        blue: 0%
        red: 100%
        green: 0%
        effect: pulse
    - delay: 3s
    - lambda: id(phase) = 1;
button:
  - platform: restart
    disabled_by_default: true
    icon: "mdi:restart"
    on_press:
      - media_player.speaker.play_on_device_media_file:
          media_file: beep
          announcement: true
    on_press:
          media_file: SimpliChime
          announcement: true
    on_press:
          media_file: BurglarAlarm
          announcement: true
# Scripts
script:
  - id: jack_detect_high
    then:
       - logger.log: "Jack detect high -> route to speaker"
       - lambda: |-
           id(my_es8388).write_byte(0x1D, 0x20);
           id(my_es8388).write_byte(0x1C, 0x10);
           id(my_es8388).write_byte(0x04, 0x30);
  - id: jack_detect_low
    then:
       - logger.log: "Jack detect low -> route to line out"
       - lambda: |-
           id(my_es8388).write_byte(0x1D, 0x00);
           id(my_es8388).write_byte(0x1C, 0x00);
           id(my_es8388).write_byte(0x04, 0x0C);
  - id: manual_listen
    then:
      - logger.log: "Manual listen button pressed"
      - if:
          condition:
            lambda: 'return id(mute);'
          then:
            - logger.log: "Manual listen -> unmute and go to waiting"
            - voice_assistant.stop:
            - wait_until:
                not:
            - lambda: |-
                 id(phase) = 1;
          else:
            - if:
                condition:
                  lambda: 'return id(phase) == 2;'
                then:
                  - logger.log: "Manual listen -> mute current playback"
                  - script.execute: mute_on
                else:
                  - if:
                      condition:
                        lambda: 'return id(phase) == 1;'
                      then:
                        - logger.log: "Manual listen -> switch waiting to listening"
                        - wait_until:
                            not:
                        - lambda: |-
                             id(phase) = 3;
                      else:
                        - if:
                            condition:
                              lambda: 'return id(phase) == 3;'
                            then:
                              - logger.log: "Manual listen -> switch listening to waiting"
                              - wait_until:
                                  not:
                              - lambda: |-
                                   id(phase) = 1;
                            else:
                              - logger.log: "Manual listen -> fallback to waiting"
                              - wait_until:
                                  not:
                              - lambda: |-
                                   id(phase) = 1;
  - id: update_led
    then:
       - if:
           condition:
             lambda: 'return id(phase) != id(last_led_phase);'
           then:
             - lambda: id(last_led_phase) = id(phase);
             - logger.log: "==>>>update_led"
             - lambda: |-
                   if(id(phase) == 0)id(start).execute();
                   if(id(phase) == 1)id(waiting).execute();
                   if(id(phase) == 2)id(external_player).execute();
                   if(id(phase) == 3)id(listening).execute();
                   if(id(phase) == 4)id(answering).execute();
  - id: start
    then:
     - light.turn_on:
          effect: slow_pulse
          red: 80%
          green: 0%
          blue: 80%
     - delay: 5sec
     - lambda: id(my_es8388).setup();
     - wait_until:
         not:
     - delay: 200ms
#     - media_player.speaker.play_on_device_media_file:
#          media_file: little_sound
#          announcement: false
  - id: waiting
    then:
     - light.turn_on:
          effect: pulse
          red: 0%
          green: 0%
          blue: 100%
          brightness: 100%
  - id: listening
    then:
     - light.turn_on:
          effect: pulse
          red: 0%
          green: 100%
          blue: 0%
          brightness: 100%
  - id: answering
    then:
     - light.turn_on:
          effect: none
          red: 100%
          green: 100%
          blue: 0%
          brightness: 100%
  - id: external_player
    then:
     - light.turn_on:
          effect: none
          red: 80%
          green: 40%
          blue: 0%
  - id: mute_on
    then:
       - if:
           condition:
             lambda: 'return fabsf(id(last_volume_cmd)) > 0.005f;'
           then:
                 volume: '0'
             - lambda: id(last_volume_cmd) = 0.0f;
       - lambda: id(mute) = true;
  - id: mute_off
    then:
       - if:
           condition:
           then:
                  volume: !lambda return(id(Vol));
       - lambda: id(mute) = false;
EDIT: It may actually be related to the “SimpliChime” button and pressing it too fast. For these small sounds I would like to have them on the device directly and use a button. Do you know if there’s a better way to integrate this into the state machine?
Regarding the other crashes, I will continue to let it run and provide the uptime plot (see if it changed compared to the one I posted here)
Hello everyone,
I wanted to run another update on ESPHome (wireless) and am getting the following errors:
INFO ESPHome 2026.1.0
INFO Reading configuration /config/esphome/muse-luxe.yaml...
INFO Updating https://github.com/RASPIAUDIO/esphomeLuxe.git@main
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
See https://esphome.io/guides/faq/#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
INFO Generating C++ source...
INFO Applying optimized lwip settings: 65KB TCP windows, 64 mailbox sizes
INFO Applying optimized WiFi settings: 64 RX buffers, 64 TX buffers
INFO Setting CONFIG_LWIP_MAX_SOCKETS to 11 (registered: api=4, captive_portal=4, mdns=2, ota=1)
INFO Compiling app... Build path: /data/build/muse-luxe
Processing muse-luxe (board: esp-wrover-kit; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/55.03.35/platform-espressif32.zip)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - contrib-piohome @ 3.4.4
 - framework-espidf @ 3.50502.0 (5.5.2)
 - tool-cmake @ 4.0.3
 - tool-esp-rom-elfs @ 2024.10.11
 - tool-esptoolpy @ 5.1.0
 - tool-mklittlefs @ 3.2.0
 - tool-ninja @ 1.13.1
 - tool-scons @ 4.40801.0 (4.8.1)
 - toolchain-xtensa-esp-elf @ 14.2.0+20251107
Reading CMake configuration...
-- git rev-parse returned 'fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).'
-- Minimal build - OFF
-- Building ESP-IDF components for target esp32
NOTICE: Processing 5 dependencies:
NOTICE: [1/5] espressif/esp-nn (1.1.2)
NOTICE: [2/5] espressif/esp-tflite-micro (1.3.3~1)
NOTICE: [3/5] espressif/mdns (1.9.1)
NOTICE: [4/5] zorxx/multipart-parser (1.0.1)
NOTICE: [5/5] idf (5.5.2)
-- ESP-TEE is currently supported only on the esp32c6;esp32h2;esp32c5 SoCs
-- Configuring incomplete, errors occurred!
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:328 (message):
  Failed to resolve component 'jsmn' required by component 'adf_utils':
  unknown name.
Call Stack (most recent call first):
  /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:377 (__build_resolve_and_add_req)
  /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:685 (__build_expand_requirements)
  /data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:740 (idf_build_process)
  CMakeLists.txt:3 (project)
========================== [FAILED] Took 9.74 seconds ==========================
Any suggestions for a solution?
Perhaps not a complete reinstallation again?
