no, they donβt - you might have missed it in my post:
The audio output options in the desktop do not have the hat as shown in your screenshot
Just before doing the test, can you confirm that you ULTRA has a blue push button ? (sorry to ask but some other user made the confusion with the MIC model in the past)
yes it does, and the box says ultra (which is what I ordered).
Bump?
Iβve dumped a fair bit of troubleshooting into this without luck. Does the silence mean youβve also run into trouble?
If so I might need to return them, as Iβm looking for something to implement somewhat soon
Cheers
Sorry for the delay, the test is scheduled for tomorrow, I will post result here
Hello I have tested it and found an issue, sorry for that. It will take a few days to fix but meanwhile you can use this installation files from Waveshare, itβs 100% compatible, I had to start from a fresh SD card with Pi OS 32 bits with desktop.
Updated the installation procedure for method 2 with a simple fork of the waveshare method
I have tried to do both methods on my Raspberry Pi 3b. They all get errors.
From systemctl status:
β wm8960-soundcard.service - WM8960 soundcard service
Loaded: loaded (/lib/systemd/system/wm8960-soundcard.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2023-03-01 21:01:32 CST; 14s ago
Process: 3303 ExecStart=/usr/bin/wm8960-soundcard (code=exited, status=99)
Main PID: 3303 (code=exited, status=99)
CPU: 1.075s
Mar 01 21:01:30 raspberrypi su[3345]: (to mike) root on none
Mar 01 21:01:30 raspberrypi su[3345]: pam_unix(su:session): session opened for user mike(uid=1000) by (uid=0)
Mar 01 21:01:31 raspberrypi su[3345]: pam_unix(su:session): session closed for user mike
Mar 01 21:01:31 raspberrypi su[3356]: (to mike) root on none
Mar 01 21:01:31 raspberrypi su[3356]: pam_unix(su:session): session opened for user mike(uid=1000) by (uid=0)
Mar 01 21:01:31 raspberrypi su[3356]: pam_unix(su:session): session closed for user mike
Mar 01 21:01:32 raspberrypi systemd[1]: wm8960-soundcard.service: Main process exited, code=exited, status=99/n/a
Mar 01 21:01:32 raspberrypi systemd[1]: wm8960-soundcard.service: Failed with result βexit-codeβ.
Mar 01 21:01:32 raspberrypi systemd[1]: Failed to start WM8960 soundcard service.
Mar 01 21:01:32 raspberrypi systemd[1]: wm8960-soundcard.service: Consumed 1.075s CPU time.
Journal:
mike@raspberrypi:~/WM8960-Audio-HAT $ journalctl -xe
Mar 01 21:02:45 raspberrypi systemd[1]: session-c8.scope: Succeeded.
ββ Subject: Unit succeeded
ββ Defined-By: systemd
ββ Support: Debian -- User Support
ββ
ββ The unit session-c8.scope has successfully entered the βdeadβ state.
Mar 01 21:02:46 raspberrypi systemd[1]: wm8960-soundcard.service: Main process exited, code=exited, status=99/n/a
ββ Subject: Unit process exited
ββ
ββ An ExecStart= process belonging to unit wm8960-soundcard.service has exited.
ββ
ββ The processβ exit code is βexitedβ and its exit status is 99.
Mar 01 21:02:46 raspberrypi systemd[1]: wm8960-soundcard.service: Failed with result βexit-codeβ.
ββ Subject: Unit failed
ββ
ββ The unit wm8960-soundcard.service has entered the βfailedβ state with result βexit-codeβ.
Mar 01 21:02:46 raspberrypi systemd[1]: Failed to start WM8960 soundcard service.
ββ Subject: A start job for unit wm8960-soundcard.service has failed
ββ
ββ A start job for unit wm8960-soundcard.service has finished with a failure.
ββ
ββ The job identifier is 1551 and the job result is failed.
Mar 01 21:02:46 raspberrypi systemd[1]: wm8960-soundcard.service: Consumed 1.002s CPU time.
ββ Subject: Resources consumed by unit runtime
ββ
ββ The unit wm8960-soundcard.service completed and consumed the indicated resources.
Was this ever resolved? I need to disable input monitoring of the line input.
I need the line in signal coming into my program but I need to disable it from coming out of the headphones
Could you tell me what exact of PI OS you have used ? thanks
itβs this verision of raspios bullseye
Is there an updated installation guide? I am running into the following error with the method 2 installation.
Hi and welcome, what is your OS exact version please?
I was on the latest version with bullseye. I see now that it may not work with that version of raspiOS. Just to confirm is there no way of getting the device to work on Bullseye at this moment in time?
My last trial on the 04/04/23 : note that due to an update of PI OS only the 64bits version on the PI OS is working, but not working with the 32 bits.
I can confirm now that my OS was β2023-02-21-raspios-bullseye-arm64-liteβ in my previous picture.
I brought several hats and Iβd like to know how to get it get full control working primarily on Buster and Bullseye.
This is when I use GitHub - RASPIAUDIO/WM8960-Audio-HAT: The drivers of [WM8960 Audio HAT] for Raspberry Pi from the installation thread on a fresh install of the latest version of Buster 32 bit. So Iβm not really getting luck anywhere.
Let me know if there is anything else I can provided for this to be assisted with asap. Thank you.
could you please try on the PI OS 64bits full version (not the light one), with the waveshare script ?
Having the same issue as @djohnson , waveshare script & PI OS 64bit full gave same error.
This seems to work on 64 bit: GitHub - Sybility/WM8960-Audio-HAT: The drivers of [WM8960 Audio HAT] for Raspberry Pi
